question about code being thrown....
Old Jan 13, 2003 | 06:24 AM
autoEXturbo's Avatar
Default question about code being thrown....
I believe the code read misfiring cylinder/piston. I was told when you lower compression that this code will get thrown. If not, i'm not sure what is the problem causing this. Hopefully it's just a misfiring plug and not something to serious.
Thanks
Old Jan 13, 2003 | 06:30 AM
Spade's Avatar
Default Re: question about code being thrown.... (autoEXturbo)
No idea what code your throwing however, it could be detonation.
Suggest you lower the boost and check the plugs and wires before doing anything crazy.
Old Jan 13, 2003 | 07:34 AM
Default Re: question about code being thrown.... (Spade)
I'm almost 100% sure it's not detonation. Only running 10psi @ 9.1:1. I will check the plugs though, I haven't changed them yet and that could be the problem. Thanks for your reply.
Old Jan 13, 2003 | 08:44 AM
Spade's Avatar
Check the connection between the wires and the plugs too.
crxnonvtec
Aug 28, 2009 11:13 AM
EK_vzla
Aug 30, 2004 01:39 PM
Shakes
Apr 18, 2004 07:20 AM
reVVin
Mar 31, 2002 07:03 PM
