93 Civic DX Misfire
93 Civic DX Misfire
Just bought a 93 Civic DX for a killer deal, I am planning on dropping a D15B into it, but until then i need it to run nice and smooth
The car starts just fine, however its only running on 3 cylniders, #2 does not fire, checked for spark and its getting it, (amazing how much of a jolt you get off a plug wire) pulling the plug you can see there is a small amount of oil on it, I have tried cleaning it off to see if it would help and it did not.
The Error codes just says Misfire on #2
Any suggestion on what else i should check?
Forgot to mention, I have done a compression check on it as well and they all check fine, however #2 is slow to get to 160
be professional
Re: 93 Civic DX Misfire (DarkElfTRP)
D15B7s are notorious for head gasket failures, so that's a possibility.
Leakdown test on the #2 cylinder will tell you more than a compression test.
Re: 93 Civic DX Misfire (Targa250R)
Oddly enough I was just reading how to make a leakdown tester, looks like I have weekend project
Any more help would be great!!!
Also the head gasket has been replaced
JJFBDF
08-26-2013 07:09 PM
honda_civic1993
10-12-2011 04:09 AM
ted
01-11-2005 04:34 AM
