93 accord eclipse turbo conversion problems
Old Apr 2, 2003 | 05:57 PM
jugheadz's Avatar
Default 93 accord eclipse turbo conversion problems
Having a problem with the turbo setup. I got the eclipse manifold redrilled, got the eclipse injectors and the safc hooked up. Well thats the good part. I have been told by a few people that the turbo will bolt right up. Well I have a TD04 and it simply wont bolt up worth anything. First I had to remove the front motor mount to make it even close. Then when I tried to drop the turbo in it wouldnt fit at all because the compressor hits the block. Is it the turbo. Do I have to use a t25 or 14b. Anyone have this setup that can help? Any help would be appreciated.
Old Apr 2, 2003 | 06:01 PM
dfoxengr's Avatar
Default Re: 93 accord eclipse turbo conversion problems (jugheadz)
u normally shave somewhere on the block (where it hits) when putting in a turbo
Old Apr 2, 2003 | 06:03 PM
jugheadz's Avatar
lol can I shave like an inch in? or maybe just half an inch. Its not on the cylinder part its right where the flywheel is.
Old Apr 2, 2003 | 06:11 PM
dfoxengr's Avatar
probly like half inch i have no idea with out looking at it..
Old Apr 2, 2003 | 06:33 PM
jugheadz's Avatar
Its the part where a nipple comes out so that the motor mount can screw into it (big nipple but is hollow). Anything I should use to grind it with?
Old Apr 2, 2003 | 08:58 PM
aznexec's Avatar
can you take some pics of your issue?
Thx
Old Apr 2, 2003 | 10:46 PM
Flamenco-T's Avatar
with eclipse's manifold flange, you can only use a T25, T28 and 14B..i don't think you can use a greddy turbo..
stan
Old Apr 2, 2003 | 10:53 PM
jugheadz's Avatar
Got it all straight now. I had to grind the spot where the bolt goes to hold the mount in away. Had to grind the whole first bolt spot off but it didnt take any time with the angle grinder. So now I have succesfully done the accord dsm turbo setup. What a relief to finally be done. Thanks for the help.
Old Apr 20, 2003 | 07:16 PM
Mike813's Avatar
i have a 97 eclipse gst and want to do the same setup to a 94 accord,
think u can take some pics of it?
or tell me step by step what needs to be done to get it working?
thanks..
poly
Nov 9, 2009 07:32 PM
holsetcivic
May 5, 2009 04:52 PM
LxAccOrd95
Jul 22, 2003 08:49 PM
xpracing
Feb 7, 2003 02:26 AM
IMPATIENT
May 11, 2002 11:03 PM
