92 civic hatch.. oil from turbine (turbo charged)
Old 01-21-2012, 03:49 PM
wild18's Avatar
Icon2 92 civic hatch.. oil from turbine (turbo charged)
hello new to this.
i have a 92 civic hatch turbocharged running on 10 psi. when i bouth the car the turbine was clean, but i recently noticed that its dar now with oil. its not dripping bad but theres oil there, i also feel like ive lost some boost. any suggestions? first turbo charged car so i dont really know a whole lot.
also.. i replaced the radiator yesterday and white smoke is coming from under the hood. could it be the spilled antifrezee from yesterday? i also thik that my fan is not qorking. would it be a bg problem since i boost every time i drive?
any suggestions would be appreciated
Old 01-21-2012, 03:55 PM
The Grumpiest
grumblemarc's Avatar
Default Re: 92 civic hatch.. oil from turbine (turbo charged)
Blown seals. What turbo? Are you running a restrictor?
Old 01-21-2012, 04:19 PM
wild18's Avatar
a/r50. what and where is a restrictor? whats bad about blown seals? or how soon do i need to replace?
Old 01-21-2012, 04:26 PM
The Grumpiest
a/r50 is not a turbo. You are in for a crash course in turbocharging. I suggest you start reading up on as much as you can because anything I say to you from now on is going to sound like gibberish. There will be people that can come along and give you a much more precise and accurate description of anything and everything I'm about to say but I'll try and keep it as simple as I can and as I understand things.
What is bad about blown seals? Really? Oil is supposed to cool the turbo. Not get into the housing and be burned off by it.
What is a restrictor?
A restrictor is used to RESTRICT the amount of pressure feeding the turbo to prevent what? Blown seals. DO you need one? Depends on the turbo.
How soon should you replace?
You don't even know what turbo you have but you actually need to have it rebuilt if you indeed have blown seals.
First lesson learned. Never buy a boosted car when you don't know anything about boost.
Is this an Ebay turbo kit?
Old 01-21-2012, 04:30 PM
The Grumpiest
Read everything in this link.
https://honda-tech.com/forums/forced-induction-16/%2A%2A%2Aforced-induction-forum-faq%2A%2A%2A-1024174/
Pay close attention to Turbo 101.
Old 01-21-2012, 06:16 PM
wild18's Avatar
https://honda-tech.com/forums/showthread.php?t=1024174
Turbo 101 page could not be found.. no restrictor.
How can I tell\know what kind of turbo my car has?
I'm very sorry for my lack of knowledge on turbos. But that's why I. JOINED to learn
Old 01-21-2012, 06:27 PM
The Grumpiest
http://www.turbobygarrett.com/turbob...Tech%20101.pdf
Take many pictures of your set up and post them.
I hope you didn't fall victim of the new trend...to buy a POS Civic for cheap, slap an Ebay turbo kit on it and then flip the car for a profit.
Old 01-21-2012, 06:55 PM
wild18's Avatar
I will post them tomorrow. How do I posgt the picture and keep the same thread? Or. Do I just makea nw post?
Old 01-22-2012, 04:43 AM
Seagull Management
94EG8's Avatar
Upload the pictures to an image hosting site like photobucket or imageshack and post the links here with an [img] tag.
Old 01-22-2012, 07:53 AM
DirtyDA9's Avatar
@Marc, I'm guessing it is an ebay turbo like a godspeed or something if it just says A/R.50 on it. This oughta be interesting. Is the "dark" in the downpipe actually oil? Or is it carbon buildup?
Old 01-22-2012, 08:00 AM
SiRCiviC94's Avatar
in for pics
Old 01-22-2012, 08:50 AM
The Grumpiest
I'm telling you! I hope he knows the difference but he didn't mention any downpipe that I remember. Just oil in the turbine. Probably running that sans filter. And I'm wondering if the coolant issue is due to blown headgasket?
I'm seeing a lot of these Ebay turbo flips popping up lately.
Old 01-22-2012, 09:47 AM
wild18's Avatar
http://s1147.photobucket.com/albums/o558/wild-18/
direct link for the pictures. hope it works
Let me know what you all think this is or what could be causing whatever its coming out of the turbine. i also noticed tht the turbine/bles are not constantly moving. when i looked at the car it was on and idling good but the turbine was not moving at all.
Thanks guys
Old 01-22-2012, 09:54 AM
Slacker93eg's Avatar
That turbo is probably in need of new seals. I'd just replace it
Old 01-22-2012, 10:01 AM
wild18's Avatar
What should i replace? just the seals or the turbo? which one and where is the best place to buy the item? any sites or stores where i could find this for cheap?
ive read that there is a line connected to the turbo that i believe gives it coolent to keep the turbo cool. im not sure if its installed on this one.
About the coolent problem. i believe the fan is not working. ill take a look at it.
Old 01-22-2012, 10:19 AM
DirtyDA9's Avatar
He means replace the whole turbo.
Is your exhaust smoking pretty bad?
Yea I have seen those quite a bit too. And I'm wondering the same about the head gasket.
Old 01-22-2012, 10:24 AM
The Grumpiest
Can't tell anything from those pics. Can we maybe get a better camera or better resolution? Maybe even real close ups?
Old 01-22-2012, 10:27 AM
DirtyDA9's Avatar
Pretty sure your turbo is just oil cooled, no coolant lines. With an oil cooled turbo you should let the car idle for a couple minute before you drive it, and a minute or two before you shut it off after driving. Look into a turbo timer.
And I'm pretty positive that's an ebay turbo, I don't think they sell rebuild kits for it, and there really isn't any way to tell exactly what brand it is, so you won't really be able to get the right rebuild kit, you are going to have to buy a new turbo.
Old 01-22-2012, 10:32 AM
wild18's Avatar
Yes it smokes. Not horribly bad but I think its bad.
Old 01-22-2012, 10:36 AM
wild18's Avatar
Ok thanks a lot. All I see on it is a/r50 and across from there I saw. 12m..
Where can I buy jus the turbo?
Old 01-22-2012, 10:54 AM
DirtyDA9's Avatar
I wouldn't buy the same turbo again, buy a real garret or something. Garret is probably your best bet for price. But you have to find one that has the same bolt pattern as the downpipe and manifold flange.
Old 01-22-2012, 10:57 AM
The Grumpiest
Do you have a speed shop/tuner near you?
Old 01-22-2012, 11:02 AM
wild18's Avatar
Not that I know of. I'm in louisville ky.
Is there a website for garret turbos? Ill take a video of it and post it on photobucket. Maybe youb guys can help me figuring out the bolt pattern
Old 01-22-2012, 11:34 AM
wild18's Avatar
I uploaded 2 videos of the car and the turbo. Hope it helps to see wht turbo I would need
Old 01-22-2012, 11:48 AM
The Grumpiest
If you live near any of these two I suggest you give one or both a call.
Mad Scientist Autohouse
2254 high street
Ashland, Ky 41101
Tuning with crome pro/gold, uberdata, emanage, dsmlink, f.a.s.t, hp tuners, AEM fic, Megasquirt, etc., etc.
hondata, ectune, aem ems, and apexi power fc
Available dynojet 248x with killer pricing...
606-615-1432 (call or text) or jarvis199@yahoo.com
I also provide ecu socketing/chipping and basemaps, and will travel!
Modern Muscle Speed Shop
Frankfort KY
Authorized Ectune Tuning Facility
Fastest Honda's and Acura's in KY
Quick Reply: 92 civic hatch.. oil from turbine (turbo charged)
