880cc to much for GSR?
Old Aug 25, 2006 | 08:11 AM
1990hondaHF's Avatar
Default 880cc to much for GSR?
I found some Precision 880cc's...my goal is at least 300 HP. Will these dump too much fuel? Oh, tuning via turboedit....thanks.
Old Aug 25, 2006 | 08:28 AM
TheHooded_Mike's Avatar
Default Re: 880cc to much for GSR? (1990hondaHF)
As long as you're gonna tune it you'll be fine. People say that big injectors have a hard time idling sometimes...but I think Jeff Evans said it's only a problem when you go to 1000cc's.
Old Aug 25, 2006 | 08:41 AM
86si's Avatar
Default Re: 880cc to much for GSR? (TheHooded_Mike)
i say use em. gives u room to grow when u get bored and wanna turn it up
Old Aug 25, 2006 | 09:41 AM
93CX's Avatar
Default Re: 880cc to much for GSR? (86si)
way overkill for 300hp, but gives you plenty of room to grow
Old Aug 25, 2006 | 09:46 AM
2000dc2's Avatar
I'm runniong them now and the idle is a little rough but nothing to bad, guzzles gas a little bit more though. I have a spare set of 470cc injectors that I'll be using until I get internals and up the boost.
Old Aug 25, 2006 | 10:08 AM
ringgold's Avatar
Default Re: (2000dc2)
I ordered 550cc injectors when i was building up my car. Somehow I received like some 720cc's or bigger and didnt find out until I put them in on the dyno to get my car tuned. Anyways Im making a little more than 300whp and my injectors are pretty big. Has a little rough idle but nothing to bad. Tuned on Crome.
Old Aug 25, 2006 | 11:24 AM
Default Re: (ringgold)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 93CX &raquo;</TD></TR><TR><TD CLASS="quote">way overkill for 300hp</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ringgold &raquo;</TD></TR><TR><TD CLASS="quote">Somehow I received like some 720cc's.....Has a little rough idle but nothing to bad.</TD></TR></TABLE>
Now I'm having second thoughts.....
Old Aug 25, 2006 | 11:26 AM
s2kdre's Avatar
Default Re: (1990hondaHF)
u can use any size u want. the ecu controls the fuel, my friend had 1600cc's with microtec.
Old Aug 25, 2006 | 12:31 PM
b16a2delsol's Avatar
Default Re: (jdmhonda)
i have 750cc's and im just running a base map and i idle pretty good still
Old Aug 25, 2006 | 01:49 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1990hondaHF &raquo;</TD></TR><TR><TD CLASS="quote">I found some Precision 880cc's...my goal is at least 300 HP. Will these dump too much fuel? Oh, tuning via turboedit....thanks.</TD></TR></TABLE>
It sounds like you're getting a good deal on them, is that right? If you are then get them because they will give you room to upgrade. They don't need to be that big for 300hp but they will work fine. You have to get it tuned either way so if you're getting them cheap it's worth it.
Old Aug 25, 2006 | 06:48 PM
rwcdrums's Avatar
I ran 880's on a stock jdm gsr and the car idled perfect!! It actually idled better then when it was stock!
Old Aug 25, 2006 | 11:12 PM
IceySC's Avatar
i have some rc 440's i'll trade you for the 880's and alittle cash?
Old Aug 26, 2006 | 03:59 AM
xenocron's Avatar
Default Re: 880cc to much for GSR? (IceySC)
I will say that you might see some annoyances when trying to use injectors that large in a TurboEdit setup, here's why:
TurboEdit backend code is still far from being fully developed...sure you can scale the stock fuel maps and tune them for 880cc injectors and the car will run, but ALL of the other maps in that code that are untouchable as of yet (delta TPS, decel, warmup enrichment, IAT/ECT correction tables, etc) will still be for 240cc injectors.
So things like throttle tip-in can go VERY rich briefly when you get on the gas causing brief bogging, when it gets VERY cold or VERY warm and you tuned the car on an average day...you can see rather large fluctuations in the AFRs because the air temp maps are assuming 240cc injectors...the list goes on.
550cc is the largest I would comfortably stick in a car with TurboEdit, but stick to 450s or less if you can, they are good to 300 whp anyways.
Sell the 880s for some coin, pick up some used DSM 450s, get them cleaned and balanced and be good.
Old Aug 26, 2006 | 11:23 AM
Default Re: 880cc to much for GSR? (xenocron)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by xenocron &raquo;</TD></TR><TR><TD CLASS="quote">I will say that you might see some annoyances when trying to use injectors that large in a TurboEdit setup, here's why:
Sell the 880s for some coin, pick up some used DSM 450s, get them cleaned and balanced and be good. </TD></TR></TABLE>
I guess I should listen to what you say because you are the guy who will be chipping my ECU soon! Since you will be doing my basemap Chris, 550's or 450'? I'll buy what you say to buy, Sean J.
Old Aug 26, 2006 | 07:20 PM
xenocron's Avatar
For anyone who has a resistor box installed from the factory, I say find a set of DSM 450s, send them out for cleaning and install them with new seals.
For anyone that doesnt have a resistor box from the factory, it is very easy to pick up a nice set of new Precision High Impedence 440cc injectors, some RCs or do the resistor box install and find a set of clean DSM 450s
Either save those 880cc for when you go bigger and better, and convert to OBD1...or sell them off in the meantime.
I guess I should listen to what you say because you are the guy who will be chipping my ECU soon! Since you will be doing my basemap Chris, 550's or 450'? I'll buy what you say to buy, Sean J. </TD></TR></TABLE>
deez92
Oct 14, 2021 07:46 AM
Sprockets
May 26, 2005 07:32 AM
yaya
Mar 14, 2004 05:07 PM
pkripper94
Apr 7, 2003 07:19 PM
