85mm FI Block?
Old Jun 11, 2005 | 07:09 AM
stizzit's Avatar
Default 85mm FI Block?
Quick question: anyone successfully used a sleeved 85mm block for FI making 400-500hp without constant head gasket problems?
Trying to decide if i need to sell my block or keep it before i buy the pistons.
This is a rebuild BTW after spinning a rod bearing so the car was 84.5mm boosted.
Old Jun 11, 2005 | 07:23 AM
DragSource's Avatar
Let the all motor guys have that one man. It's getting pretty thin.
Old Jun 11, 2005 | 07:30 AM
mattcivic's Avatar
Default Re: 85mm FI Block? (stizzit)
i remember reading an article on a guy with 85mm running 550 hp for about 2 years and its still going. it was some yellow type r from seattle go to google and type in 550hp type r and it should pop up for ya thing is ******* SICK!
Old Jun 11, 2005 | 12:41 PM
boosted92's Avatar
Default Re: 85mm FI Block? (mattcivic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mattcivic &raquo;</TD></TR><TR><TD CLASS="quote">i remember reading an article on a guy with 85mm running 550 hp for about 2 years and its still going. it was some yellow type r from seattle go to google and type in 550hp type r and it should pop up for ya thing is ******* SICK!</TD></TR></TABLE>
https://honda-tech.com/zerothread?id=986127
You mean that one? He worked on the car for 2 years, not that he drove the car for 2 years.
Arn't you glad you went 84.5mm bore for that 2 HP gain, now that you've toasted your motor and needed to rebuild? That's why I always say 83mm max to start with, but nobody listens
Old Jun 11, 2005 | 08:59 PM
mattcivic's Avatar
Default Re: 85mm FI Block? (boosted92)
oh **** i thought that didnt sound right oh well its still a ****** BEAST
Old Jun 12, 2005 | 06:02 AM
stizzit's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by boosted92 &raquo;</TD></TR><TR><TD CLASS="quote">https://honda-tech.com/zerothread?id=986127
Arn't you glad you went 84.5mm bore for that 2 HP gain, now that you've toasted your motor and needed to rebuild? That's why I always say 83mm max to start with, but nobody listens </TD></TR></TABLE>
I didn't buid the motor, thanks, ***.
Old Jun 12, 2005 | 09:28 AM
mattcivic's Avatar
when i waste my 84mm sleeved gsr im gunna just bore it to 85mm so i guess i will find out that happens. maybe i will just bore it to 86 and make it my new n/a block??? oh well good luck on the build
Old Jun 13, 2005 | 11:28 AM
stizzit's Avatar
anyone else have any input on this? thx
Old Jun 13, 2005 | 02:28 PM
GSC Motorsports's Avatar
85mm is fine
our race engine last year was 85mm - we made over 700 whp with it, ran it all season and it is still running strong - just pulled it out and put a fresh one in this year and the 85mm is sitting in the shop as a backup ready to go
James Innes
Old Jun 13, 2005 | 05:48 PM
stizzit's Avatar
Default Re: 85mm FI Block? (GSC Motorsports)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GSC Motorsports &raquo;</TD></TR><TR><TD CLASS="quote">85mm is fine
James Innes</TD></TR></TABLE>
Really appreciate the experience!
May i finish it off with what type of head gasket you were using and if you were oringed, step decked, or flat decked?
Thanks!!!
Old Jun 13, 2005 | 05:58 PM
b00stedbyFastrax's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by stizzit &raquo;</TD></TR><TR><TD CLASS="quote">
Thanks!!! </TD></TR></TABLE>
I would like to know this also.
Old Jun 13, 2005 | 10:22 PM
Type-GS-R-Turbo's Avatar
I'm in this same situation, I would like to know what headgasket you used aswell.
Old Jun 14, 2005 | 07:39 AM
Default Re: (Type-GS-R-Turbo)
Golden Eagle 85mm Headgasket - they take a stock one and bore it to match the size of the cylinder - work excellent
our blocks are o-ringed as well
Old Jun 14, 2005 | 09:42 PM
ooh, yeah that probably helps, I'm thinking a 85mm cometic
Old Jun 15, 2005 | 06:46 AM
earl's Avatar
Default Re: (GSC Motorsports)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GSC Motorsports &raquo;</TD></TR><TR><TD CLASS="quote">our blocks are o-ringed as well</TD></TR></TABLE>Can you post a pix of your 85mm o-rings? I didn't think there was enough room between the cylinders to do that successfully. We have run 85mm Benson blocks on 35lbs of boost with no problem in our race car but I think it would be way too much for a street motor.
Old Jun 15, 2005 | 08:07 AM
Default Re: (earl)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by earl &raquo;</TD></TR><TR><TD CLASS="quote">Can you post a pix of your 85mm o-rings? I didn't think there was enough room between the cylinders to do that successfully. We have run 85mm Benson blocks on 35lbs of boost with no problem in our race car but I think it would be way too much for a street motor.</TD></TR></TABLE>
the 85mm block that we ran last year that has the o-rings is still assembled with the head on it so i don't have any pictures that i can put up of it, i will check around my old photos and see if i happened to take any of the build
Old Jun 15, 2005 | 03:12 PM
X-Mazda 3 Racer's Avatar
Earl, just FYI, 85 mm is the largest that we can offer o-rings.
Old Jun 15, 2005 | 03:49 PM
earl's Avatar
Default Re: (GoldenEagleMfg.com)
Just doesn't seem like enough meat where the cylinders come together (the most critical spot) to hold the o-rings at high boost.
Old Jun 15, 2005 | 03:50 PM
Default Re: (earl)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by earl &raquo;</TD></TR><TR><TD CLASS="quote">Just doesn't seem like enough meat where the cylinders come together (the most critical spot) to hold the o-rings at high boost. </TD></TR></TABLE>
I haven't had any issues. Ran it on Gardella's Civic and Bergenholtz's CRX for a long time, no sweat!
I will try to get you a pic!
Old Jun 17, 2005 | 03:28 AM
stizzit's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GoldenEagleMfg.com &raquo;</TD></TR><TR><TD CLASS="quote">I haven't had any issues. Ran it on Gardella's Civic and Bergenholtz's CRX for a long time, no sweat!
I had you guys step deck my block, at 85mm do you think that'll work also?
Old Jun 17, 2005 | 08:08 AM
Default Re: (stizzit)
Sure will, the o-ring is just for added insurance on extremely high boost levels!
Old Jun 17, 2005 | 10:00 AM
turbo*s2k's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GSC Motorsports &raquo;</TD></TR><TR><TD CLASS="quote">Golden Eagle 85mm Headgasket - they take a stock one and bore it to match the size of the cylinder - work excellent
But what if you need a thicker headgasket? Then I'm assuming you'd have to go through cometic...
Old Jun 17, 2005 | 10:03 AM
Default Re: (TurboChrgd_Civic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TurboChrgd_Civic &raquo;</TD></TR><TR><TD CLASS="quote">
But what if you need a thicker headgasket? Then I'm assuming you'd have to go through cometic...</TD></TR></TABLE>
why not just build the engine correctly to begin with and not have to worry about running a thicker headgasket, etc, etc
but to answer your question - i guess cometic would be an option although i haven't always seen the best results with them, just my .02 cents
Old Jun 17, 2005 | 10:09 AM
turbo*s2k's Avatar
but to answer your question - i guess cometic would be an option although i haven't always seen the best results with them, just my .02 cents</TD></TR></TABLE>
Well, when I had b16 block done a few years ago by Golden Eagle I was told to run a .040 head gasket. Are you saying they didn't build it right?
My recent build done by Earl I was able to run the standard one .030. I was told that it depends on the blocks not necessarily the person putting it together.
Old Jun 17, 2005 | 10:11 AM
My recent build done by Earl I was able to run the standard one .030. I was told that it depends on the blocks not necessarily the person putting it together.</TD></TR></TABLE>
dunno - i never heard it that way but i could be wrong - just going off my experience - other than trying to drop the compression i never thought there would be another reason to run a thicker headgasket, anyone else have insight?
