84mm sleeved b16?
Old Dec 14, 2002 | 06:32 AM
Mr. Vapor's Avatar
Default 84mm sleeved b16?
is it safe to get the 84mm darton sleeves for my b16? would this create any problems? im fearing that it wil leave me with too thin of walls....i could be way off.
also, would i just use B20 Pistons? will they fit on a b16 rod, crank etc. will they have proper head clearances?
what do you guys think?
Old Dec 14, 2002 | 07:08 AM
ekb18c's Avatar
Default Re: 84mm sleeved b16? (NYb16)
You can do 84mm however it just leaves you less room to play with in the near future.
I mean just let's say you scare up the walls pretty bad and you decide to go 84.5mm and then you damage it again, what now? 85 is too thin In My Opinion, you would have to get new sleeves again.
You know what I'm saying? If it was a race car and you don't really car about what happens to the motor, yeah sure go 84mm.
If you want more displacement and a little bit more torque then go 83mm.
When ordering pistons just say you want 83mm honda pistons
I'm not saying 84mm is bad, but for me personally I like to have a little room to play with just incase.
HTH
Old Dec 14, 2002 | 07:22 AM
Mr. Vapor's Avatar
Default Re: 84mm sleeved b16? (ekb18c)
where would i get a nice low compression turbo piston in 83mm does JE make one?
Old Dec 14, 2002 | 08:25 AM
ExospeedAMcrx's Avatar
84mm is a good street bore but of course you would need to have it sleeved.
if you dont want to go that big, we have been using custom ARIAS 83mm pistons for some sleeved blocks we are doing
Old Dec 14, 2002 | 09:30 AM
Mr. Vapor's Avatar
Default Re: 84mm sleeved b16? (exospeedAMcrx)
got any pricing on the Arias 83mm?
Old Dec 14, 2002 | 02:30 PM
ekb18c's Avatar
Arias, JE or anybody else will have 83mm or can custom make it. It just takes longer for custom pistons.
Sent ya IM about pistons prices.
Old Dec 14, 2002 | 03:47 PM
tSuperbike69's Avatar
Who cares if you damage a Darton Sleeve? They are not like Golden Eagle where you have to buy a whole new set. You can buy Darton Replacement sleeves for hella cheap. Under $50 ea I believe. 84mm all the way man.
Old Dec 15, 2002 | 07:36 AM
Mr. Vapor's Avatar
Default Re: 84mm sleeved b16? (tSuperbike69)
then the $200 to have the old one taken out, and teh one put in
B16b-EJ8
24
Oct 16, 2006 02:48 PM
7rrivera7
Nov 29, 2005 09:51 AM
quik sol
Feb 20, 2004 09:22 PM
teamrocket si
Jan 11, 2003 03:06 PM
shingles
Jun 4, 2002 08:07 AM
