je b16 pistons
Old Jan 10, 2003 | 02:23 PM
teamrocket si's Avatar
Default je b16 pistons
I bought a set of 84mm Je pistons for my b16 build up. The pistons are 10.5 to 1 b20 pistons. I was told they would come out to be about 9.5 to 1 in a b16. Is this about right?
Old Jan 10, 2003 | 07:02 PM
turbo Si's Avatar
Default Re: je b16 pistons (teamrocket si)
We'll I know for sure that if you put a sey of GSR JE pistons in a B16 that it will lower a compression point. For instance if you put a 9:1 in a B16, it will end up being 8:1. Sucks huh!
As for a B20 into a B16......i'm not for sure. Call JE?
Old Jan 10, 2003 | 09:24 PM
Mr. Vapor's Avatar
Default Re: je b16 pistons (turbo Si)
maybe im confused, but how the hell willl and 84mm B20 piston fit into an 81mm B16?
wont you have ALOT of gap there?
Old Jan 10, 2003 | 09:30 PM
MotorMatrix.com's Avatar
I am a bad person
Default Re: je b16 pistons (NYb16)
I know for sure the b20 piston works in the b16. I was told the compression comes out to be like 9.2:1.
Old Jan 11, 2003 | 03:11 AM
turbo Si's Avatar
Default Re: je b16 pistons (MotorMatrix.com)
I'm assuming he's boreing it out!
Old Jan 11, 2003 | 05:49 AM
Yeah, I'm going the whole nine yards.
Old Jan 11, 2003 | 10:24 AM
turbo Si's Avatar
resleeving as well?...i hope!
Old Jan 11, 2003 | 11:02 AM
Yeah, I am resleeving. I just haven't decided if I I'm getting GE sleeves or the darton closed deck... Got any suggestions? I think the Darton would have more cooling issues
Old Jan 11, 2003 | 03:01 PM
Mr. Vapor's Avatar
OHHHH so you are boring your block to 84mm. Ok for some reason i thought you were going to try and put an 84mm piston into your 81mm block.
ok so is this correct?
Old Jan 11, 2003 | 03:06 PM
turbo Si's Avatar
I personally like Golden Eagle. To me it's the best and the price is great!
As for piston's I would go with Weisco's! They have a new design and also make a piston for the B16. I run an 8.8:1. Check them out. There lighter than JE's as well! They are also much cheaper!
SSVTi
Aug 2, 2006 08:14 AM
Ek Alex
Jun 11, 2006 09:13 AM
quik sol
Feb 20, 2004 09:22 PM
vti2
Dec 2, 2003 04:28 PM
shingles
Jun 4, 2002 08:07 AM
