84mm bored b16
Old Oct 9, 2002 | 12:13 AM
BudaKai's Avatar
Default 84mm bored b16
Just curious if there are any down falls with 84mm b16 running about 2.0 bar? Like piston wobble or breaking rings with such a large bore and short stroke. No one has been able to answer this to my needs. You know like in theory it's not a good idea, but I reality does this stuff happen?
Old Oct 9, 2002 | 05:55 AM
The sweed's Avatar
Default Re: 84mm bored b16 (tzsir)
I´m doing just that thing. It´s better to bore than to stroke. The b16 has a 1,74 rod/stroke raito witch is close to perfect so don´t mess with that. You should have no problem at all.
Old Oct 9, 2002 | 11:38 AM
BudaKai's Avatar
Default Re: 84mm bored b16 (The sweed)
I'm already aware of all that info I need to know about it at say ~10,000rpm. And please don't tell me that no cam makes power there, because I'm going to be running ~40psi of boost in the coming spring with the ferrea rollers and crane all motor cams and 9.5/1 scr.
Old Oct 9, 2002 | 12:55 PM
mos's Avatar
mos
Well it's obviously going to be larger and therefore slightly heavier, which does effect how high you can rev. Assuming everything else is up to 10kRPM standards I would think it'd be fine.
Old Oct 9, 2002 | 02:24 PM
Ltech's Avatar
Default Re: 84mm bored b16 (mos)
40 psi? Boy you got some *****. Really you got some *****.
Old Oct 9, 2002 | 02:49 PM
Full-Race Geoff's Avatar
if youre gonna run rollers, you better get some DEEP *** valve reliefs in some super thick pistons!
good luck, its a long road.
solo227
Sep 8, 2009 11:21 PM
MKcrxB16
25
Jul 20, 2006 11:36 AM
af97civic
Dec 2, 2003 04:31 PM
Dan GSR
Apr 24, 2003 08:39 AM
blazin
Aug 27, 2002 08:13 PM
