76mm pistons headGasket Selection
Old May 26, 2014 | 10:36 AM
G-power's Avatar
Default 76mm pistons headGasket Selection
hi all
for best selection 76mm 77mm ?
Old May 26, 2014 | 05:29 PM
rev-speed's Avatar
Default Re: 76mm pistons headGasket Selection
Originally Posted by G-power
hi all
the stock 75
Old May 26, 2014 | 11:15 PM
cyanid3's Avatar
http://www.goldeneaglemfg.com/index....roducts_id=250
Old May 27, 2014 | 10:14 AM
G-power's Avatar
this gasket 77mm
my pistons 76mm ?
Old May 27, 2014 | 01:15 PM
rev-speed's Avatar
Look I've used 85mm pustins with stick 84mm head gaskets
Old May 27, 2014 | 08:54 PM
cyanid3's Avatar
this gasket 77mm
my pistons 76mm ?
Check that website. There are headgaskets available in 76mm too.
Don't think the stock headgaskets can work with 76mm on D series. The maximum OEM oversize is 75.5mm.
Old May 28, 2014 | 08:39 PM
adam00's Avatar
Ive had an oem y8 gasket 75mm on a 76.5mm block no problems
Old May 28, 2014 | 10:00 PM
wantboost's Avatar
Who is Mr Robot?
It's not ideal but it does work.
I think golden eagle will also laser cut d series gaskets just like they do b series. contact them.
I know cometic makes bigger gaskets but their performance is spotty.
Old May 29, 2014 | 12:44 AM
NotARaCist's Avatar
I never narc'd on nobody!
You shut your blasphemous mouth!
But seriously, EVERY major manufacturer makes spotty head gaskets, if you ask the right person. I'm using Cometic, a number of my friends are using Cometic, and they've never had failures. I can't speak towards it, since my motor is still sitting on a stand...but considering one of my friend's heavily boosted motors has survived 6 years, 100,000 miles, and two chassis', I'm gonna call it a win.
Cliffs: As long as you buy a well known, name brand head gasket, and as long as you install it correctly, you shouldn't have any problems.
CALC!_JUST_du_IT!
Aug 9, 2007 04:41 PM
dude_123
Apr 12, 2007 05:56 AM
LilCivic04
Aug 21, 2005 08:35 PM
GS-Rcivic
Feb 20, 2004 09:33 AM
