68mm throttle body, is it worth it?
Ok guys the local shop as 65 and 68 mm throttle bodys for 104.99 this is crazy. i am running a D-series turbo and wanting to know if its worth it and will i be able to tell some difference?
Re: 68mm throttle body, is it worth it? (00situner)
Those are for pussies, real men use a 75mm Mustang TB.
But seriously, when I was running a turbo I put a 65mm on mine and didn't notice a difference, and plenty of people make a lot of power on stock TB's.
Location: The Village Hidden in the Leaves: Seattle, WA
what size is your IC pipes? u don't need to get one bigger than your IC pipes IMO.
so if you're ic pipes aren't bigger than 2.5 then u don't need bigger than a 65mm throttle body
Moderator in Chief
Re: 68mm throttle body, is it worth it? (rmcdaniels)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rmcdaniels »</TD></TR><TR><TD CLASS="quote">Those are for pussies, real men use a 75mm Mustang TB.</TD></TR></TABLE>
lol real men have turbos attached to their throttle bodies not air filters.
Re: 68mm throttle body, is it worth it? (Muckman)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Muckman »</TD></TR><TR><TD CLASS="quote">
lol real men have turbos attached to their throttle bodies not air filters. </TD></TR></TABLE>
owned
im running the stocker but the stock gsr is alot different then a stock single cam....those things are tiny..then again so are the ports in the he ad
owned
LagunaSecaEG
08-06-2006 06:14 PM
