6 puck clutch
Old Mar 18, 2005 | 05:10 PM
oxSLEEPERxo's Avatar
Default 6 puck clutch
I have a 6 puck clutch, is the clutch suppose to be kinda jerky? the clutch is brand new. What are yall experience with the 6 puck clutch, jerky, smooth, rough?
Old Mar 18, 2005 | 05:18 PM
Bailhatch's Avatar
Default Re: 6 puck clutch (oxSLEEPERxo)
yup, abrupt engagement, weird noise and sometime they shudder if you try and slip them. You'll get used to it. I love my ACT 6 puck
Old Mar 18, 2005 | 05:51 PM
platinum00's Avatar
Default Re: 6 puck clutch (Bailhatch)
what kinda 6 puck
sounds normal to me.
took a couple days to get used to it. but now i would have any other...
Old Mar 18, 2005 | 05:52 PM
B20TDC2's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Bailhatch &raquo;</TD></TR><TR><TD CLASS="quote">yup, abrupt engagement, weird noise and sometime they shudder if you try and slip them. You'll get used to it. I love my ACT 6 puck </TD></TR></TABLE>
Old Mar 18, 2005 | 06:25 PM
adseguy's Avatar
Default Re: 6 puck clutch (B20TDC2)
I have an Action 6 puck 2MD...great power and engages very quickly (when you want it to). It kinda sucks for daily driving since 1st gear is the hardest to put it into. Don't slip them tooo much because your stock flywheel won't take the abuse. In first, I rev to 1,5-2 grand and engage for about a second or too before it drops to 1 k rpm...seems to best method after 6 months of driving. Find your own method but don't over rev the start to get a smooth engament, because it's not made to be a totally smooth engament. Just tell your friends...hey i have a lot of HP under the hood...deal with it
Old Mar 18, 2005 | 06:43 PM
Default Re: 6 puck clutch (adseguy)
yea, engagement sucks lol
Old Mar 18, 2005 | 06:48 PM
94lsboost's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by adseguy &raquo;</TD></TR><TR><TD CLASS="quote">I have an Action 6 puck 2MD...great power and engages very quickly (when you want it to). It kinda sucks for daily driving since 1st gear is the hardest to put it into. Don't slip them tooo much because your stock flywheel won't take the abuse. In first, I rev to 1,5-2 grand and engage for about a second or too before it drops to 1 k rpm...seems to best method after 6 months of driving. Find your own method but don't over rev the start to get a smooth engament, because it's not made to be a totally smooth engament. Just tell your friends...hey i have a lot of HP under the hood...deal with it </TD></TR></TABLE>
Exactly what I do...Glad to see someone else likes that method. Sometimes I can get mine to take off smoothly from 1200 rpms or so, but usually it's 1500ish and jerky. The wife DOES NOT try to drink anything when I take of now.
Old Mar 18, 2005 | 06:51 PM
abnaasefmb's Avatar
yeah that sounds about right but let it break in a little bit and it will get worse. i refer to mine not as a clutch but as an on/off switch.
Old Mar 18, 2005 | 06:56 PM
Bailhatch's Avatar
Default Re: 6 puck clutch (abnaasefmb)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by abnaasefmb &raquo;</TD></TR><TR><TD CLASS="quote">yeah that sounds about right but let it break in a little bit and it will get worse. i refer to mine not as a clutch but as an on/off switch.</TD></TR></TABLE>
ha, that sounds about right.
About the flywheel wear issue...I pulled my HDR6 a couple days ago and it was in really good shape. On a factory flywheel it had a very mild wear after about 4500-5k. looked almost new actually. I slip it a lot so I was expecting much worse wear.
Old Mar 18, 2005 | 07:03 PM
lol when i brought my 6puck, i thought engage will be smooth but with a stiffer pedal, i guess i was wrong, what full face clutch will yall recommend? I probably switch it out later down the road
Old Mar 18, 2005 | 07:17 PM
dennis's Avatar
If you want smooth, get kevlar, like an action 1 or 2ks. I have an action 1md (sprung 6 puck) and once you get used to driving it, it's fine. You just have to rev a little higher in 1st before engaging. About the only time it's not optimal is in bumper to bumper trafic.
Old Mar 18, 2005 | 08:58 PM
Default Re: 6 puck clutch (dennis)
at what rpm do yall shift at for smooth engagement, so far its 1200rpm
Old Mar 18, 2005 | 09:16 PM
abnaasefmb's Avatar
rev to about 3k to slip clutch from a stop in normal driving.
Old Mar 18, 2005 | 11:34 PM
stealthmode62's Avatar
I've heard from alot of customers that the clutch specialties clutches will chatter a bit if you "ride em", but after about 5k miles it breaks in and doesn't chatter anymore. Not sure what you're using or if it will help, that's just what they tell me.
Old Mar 19, 2005 | 07:40 AM
Default Re: 6 puck clutch (stealthmode62)
bump for more opinions on where yall shift at to get a smooth engagement
MachinaInfernus
Feb 24, 2007 07:34 PM
imadigitalgod
11
Nov 18, 2006 11:27 PM
SOHC_Brian
Aug 23, 2004 09:58 AM
slimbo
Mar 31, 2004 03:47 AM
HATCHFREEK
Apr 7, 2003 08:40 AM
