Need help on spool up times for a t3/t4 turbo.....
I'm getting ready to replace my t25 turbo with a t3/t4 turbo since the seals are going out cause I'm a moron (don't ask lol its a dumb story). Well since I really liked the way the t25 would spool up (I'm talking about full boost by 2500 rpms!) I'd like to find a t3/t4 that spools up similar to the t25. This is going on a stock d16y7 and I plan on no more than 8-10 psi with a Tial 35mm wastegate.
A friend told me that I should check into the .48 a/r 50 trim but wasn't to sure about the spool up time. Can anyone tell me or estimate? Also, is there a t3/t4 turbo the spools as fast or close to the t25 (2500 is full boost) and is still capable of making 10 psi max?
Thanks a ton,
Nick
Thanks a ton,
Nick
Re: Need help on spool up times for a t3/t4 turbo..... (T25 civic)
it is pointless to try and find a big turbo that spools fast. I just bought a T3/T04e for my d16, .50 trim and .50 A'R, I'll let you know what the spool times are...but I'm not worried about that, a T3/T4 doesn't start making it' true potential until about 10psi and more....so I suggest you either replace your t-25 or go w/ a smaller turbo, maybe 16g etc...
Re: Need help on spool up times for a t3/t4 turbo..... (CzanSOHC)
The problem with the 16g is trying to find a manifold outside of the kit. I was going with the t3/t4 because it was the easiest to find a new manifold for. keep the suggestions comming,
Nick
Nick
equal length tubular manifold, 3" dp, 3" exhaust, ballbearing turbo, lightweight fly wheel, larger displacement, nitros, smaller a/r.
Re: Need help on spool up times for a t3/t4 turbo..... (rice4life)
Those are all good but I was looking for more help on the turbo side. Like what kind of specs to get on the t3/t4, or recomending another turbo with manifolds that are easy to find for a d-series motor.
Nick
Nick
On your car dude, you could expect full boost by no earlier then 4000rpms... My guess is a tad beyound that. Of course this depends on the trim. My t3/t4 doesn't hit full till 4300rpms. I could only imagine how much more lag would be in your car being its smaller displacement. Of course the smaller t3/t4b might be a tad quicker, not by a whole lot though.
Re: Need help on spool up times for a t3/t4 turbo..... (shadowdawn)
Since a T3/T04 is a hybrid of a T3 turbine and T04E compressor housing, then doesn't it stand to reason that one could "mate" a T25 turbine and T3 compressor wheel. I think a mix of doing this and forking the cash over for ball-bearings would be more than sufficient. At least do the bearing option.
Good Luck,
Nick
Good Luck,
Nick
Re: Need help on spool up times for a t3/t4 turbo..... (Nikolai)
That would be a way but I was looking for a cheaper option, where I could just buy a t3/t4 turbo with a small enough ratio or trim to do what I want. What about a t3 turbo instead of a t3/t4? Would they use the same manifold?
Just get a t3 60 trim. It sounds like what you are looking for and they will be less money too.
Re: Need help on spool up times for a t3/t4 turbo..... (TURBO18)
Wait. First of all, what kind of manifold are you using now to mate the t25 to a D-series? If you're using the STD/HF manifold w/adapter plate, then I'm assuming it's flanged for the Mitsubishi turbos...hence the t25.
Anyways, check out AGPTurbo.com. They can REBUILD your T25 into a killer T28. It'll flow about as much as a BIG16G, but spool is instantaneous. ForcedPerformance.net also rebuilds t-2smalls to a Big28 too. Let's just say that their Big28 is good enough for high 11's on a full weight 2G DSM.
And the best part is that you send in your old core and they'll give you credit towards the bigger turbo.
Re: Need help on spool up times for a t3/t4 turbo..... (Prelude_RCR)
Yeah I'd love to just keep my t25 cause I love the instant spool, but I'm having trouble since the wastegate isn't opening, so I'd have to buy an external wastegate and weld the flapper shut. BTW I have a custom made manifold with a flange for an external wastegate. I bought it from DSF on this board.
Nick
Nick
yeah everyone else is telling me there is no point going to a bigger turbo if I want the spool to be the same on my ***** *** motor. They don't see the point in going out and buying a new manifold, turbo, downpipe and wastegate and knowing that its not going to be exactly what I want, when all I'd have to do is buy another t25 for 100 bucks max, and have the flapper welded shut, and buy a tial wastegate and be done. Thanks for all your comments
Nick
Nick
