550's + hondata +built b18c5
Old Nov 12, 2001 | 05:40 PM
markaria's Avatar
Default 550's + hondata +built b18c5
I am currently getting my block built (je 9:1/crower/sleeved/decked), and plan on going with the hondata and 550cc rc's. Would it matter if I get saturated vs peak and hold? If properly installed is there an advantage to one versus the other?
I'd like to run about 10-12 lbs of boost on the street and up to about 20lbs on race gas. Any recommendations? Thanks for your help.
Old Nov 12, 2001 | 06:04 PM
dustin's Avatar
Default Re: 550's + hondata +built b18c5 (markaria)
Can't run 20psi on 550cc injectors. Get 720cc or larger.
Old Nov 12, 2001 | 07:37 PM
Reverend's Avatar
Default Re: 550's + hondata +built b18c5 (dustin)
ok, will someone answer his question, because I was wondering the difference between saturated and peak & hold, also. What are the pros/cons to each and why is one favored over the other?
I'm glad I found this post before I created a new topic
Old Nov 13, 2001 | 12:12 AM
paulzy's Avatar
Default Re: 550's + hondata +built b18c5 (Reverend)
to my knowledge...both types are about, if not the same...They just use different voltages to work.
The pro of a p&h style over the saturated would probably just be the lower prices(that I've seen).
What you should really worry about is if you want lucas style or pintal style injectors...
Anybody correct me if I'm wrong
Old Nov 13, 2001 | 05:06 AM
rtype11's Avatar
Make sure you get atleast 720cc, which are just the lower limit for 20PSI - get ford mustang 83lbs injectors reworked for your car and save some money, you may even be able to get a decent idle out of them.
Old Nov 13, 2001 | 12:33 PM
Dublocivic's Avatar
Default Re: 550's + hondata +built b18c5 (rtype11)
Its all about how much hp can be made before hitting lees than optimal af ratios. You cannot say 550cc's can only support 20 psi. The setup Im going to be using is putting down 500hp @15psi soo... its kind of more about how dense the charge and how much power you make.. it can only put out 550cc/min which supports Xamount of power.
H22Luda720
Feb 28, 2006 04:57 PM
oemDC2
Nov 22, 2003 09:41 AM
madman604
Feb 11, 2003 09:45 AM
WykidEH
Oct 12, 2001 03:38 AM
boomslang
Aug 29, 2001 06:50 PM
