5 bolt vs 4 Bolt
Old Jan 11, 2007 | 01:19 PM
JDMCRX's Avatar
Default 5 bolt vs 4 Bolt
I know this has been covered before ive looked.
If the compresor housing is on the tranny side will the 4 bolt side closer to the block or furth from the block compaired to the 5 bolt
Old Jan 11, 2007 | 02:05 PM
project dc2's Avatar
Default Re: 5 bolt vs 4 Bolt (JDMCRX)
closer to the block
Old Jan 11, 2007 | 06:59 PM
JDMCRX's Avatar
Default Re: 5 bolt vs 4 Bolt (project dc2)
By how much i want to do a GT30r on my D series and right now i have a T3T4 .51 comp and 5 bolt exhaust and it hits.
I was thinking maybe a .75" spacer on the head to manifold?
Old Jan 11, 2007 | 07:50 PM
HiProfile's Avatar
Thats sort of a band-aid, but I imagine it could work. The best solution would be to hack off the turbo flange and weld it at a slight angle to move the turbo out or over a bit.
Old Jan 12, 2007 | 07:17 AM
RyanEJ8's Avatar
Why not flip the turbo around so the compressor side is on the drivers side? That's the way I have mine with the 4 bolt.
Old Jan 12, 2007 | 07:25 AM
mike1114's Avatar
Default Re: 5 bolt vs 4 Bolt (RyanEJ8)
buy a new manifold and your problem will be solved.
Some turbo manifolds like drag, were designed around a 5-bolt style exhaust housing.
Others like max-rev, were designed around a 4-bolt style.
I had this problem when I first bought my setup. Even grinding the block would not solve it as I would have to grind too much, so I sold the manifold I had and bought one I knew worked with a 4-bolt exhaust housing.
I think you may know why but the turbos angle differently from the centerline/flange.
Speed94
Aug 1, 2008 06:35 AM
tyflip2
Jan 29, 2004 05:04 PM
rextec
Dec 11, 2003 05:56 AM
tegasaurus
Jul 24, 2003 03:48 AM
integranator
Feb 5, 2003 03:51 PM
