5 bolt internal wg down pipe question
Old Nov 19, 2008 | 09:05 AM
Boosted_B_Series's Avatar
Default 5 bolt internal wg down pipe question
Hi,
I am fabbing a 3" dp for a customer and he has a small internally gated turbo.
My question is about the 1" wg port, with externally gated setups with the 5 bolt flange blocks this port off.
On his factory dp its has a bell mouth welded to the 5 bolt that combines turbine opening and wg port and routs them into the same pipe.
Can I block this wg port off, run an external 1" dump tube out of the flange or do I have to fab up a collector like the factory bell mouth?
Old Nov 21, 2008 | 12:41 PM
dpetro1's Avatar
either way should work just fine
Old Nov 25, 2008 | 01:18 PM
ok thanks
J240sx
Apr 3, 2012 05:39 PM
1SlowSi
Feb 5, 2005 02:27 PM
FuriousGeorge
Sep 4, 2004 08:24 AM
