400hp is the goal
off the wall question but boost can only be turned up and held at that boost level as good as its boost controller & w/g spring? can a manual boost controller do the trick or does it have to be electronic?
i used a manual on my setup, it works fine. its recommended that u only double the WG spring. so if your boosting 20psi, try to get a hold of at least a 10psi spring....not sure what your running now? or are u running no boost controller just the WG spring right now?
yeah i wouldnt push 20psi on the 7psi spring, any tial dealer should be able to get u a spring for your WG. many shops keep them in stock if they do a lot of tuning. when i got my car tuned we messed around with a few different springs.
What turbo are you running?
My setup:
9:1 wiseco pistons
Eagle Rods
Edelbrock victor X intake manifold
stock throttle body
Full race exhaust manifold
Turbonetics T3/T4 62-1
3"DP
3" cold side piping
2.5" hot side piping
Dynoed at 353whp and 254ft trq on 12 psi and LS tranny (LS tranny blew after Dyno
My setup:
9:1 wiseco pistons
Eagle Rods
stock throttle body
3"DP
3" cold side piping
)Thread
