4" Open Downpipe?
Old Aug 12, 2009 | 07:14 PM
kte324's Avatar
Default 4" Open Downpipe?
I was planning one running a 4" open downpipe, but I was thinking of it being to big and affecting my a/f readings or am I just thinking about it to much? Setup will be 84mm b16 w/ bw s362 6-650whp range.
Old Aug 12, 2009 | 07:16 PM
ashb82's Avatar
Default Re: 4" Open Downpipe?
how do you keep it from hitting the pavement i wish i could run one that big but i think it would drag all the time
Old Aug 12, 2009 | 08:10 PM
haas480's Avatar
i have one and it doesn't hit. i i have 4 inch down pipe. then its v banded to a 4" bend under the block and pretty close to oil pan (oil pan is heat reflective taped and all exhuast is heat wrapped with DEI titanium lava rock wrap to reduce temps). then that section is vbanded to a reduced 3" straight pipe all the way back and out. So when i want to run the 4" downpipe. i just un vband the mid section bend under the block. works good. and my 02 bung is half way down the downpipe. never have problems with tuning.
Old Aug 12, 2009 | 08:12 PM
haas480's Avatar
thats just a mock up first pic. and then its done in the second. don't mind the poor welds =[. out of gas and had to turn it on A so it wouldn't burn thru. (good excuses 8])
Old Aug 13, 2009 | 07:29 AM
kte324's Avatar
I was thinking of it being to big and the wideband picking up some outside air.
Old Aug 13, 2009 | 08:56 AM
93supercoupe's Avatar
If you have it closer to the turbo than the outlet, then it shouldnt be effected.I had this problem, but i moved it further up-stream and all was well.
Old Aug 13, 2009 | 09:43 AM
Evile140's Avatar
That heat wrap is going to make the manifold fall apart pretty quickly.
Old Aug 13, 2009 | 12:14 PM
haas480's Avatar
how is the manifold going to fall apart? if you think it cuz the heat is trapped in, it won't effect it enough. people run heat wrap for years, never heard of one problem. or are you referring to it affecting the manifold another way?
Old Aug 13, 2009 | 05:21 PM
kte324's Avatar
That is what I was thinking. The dp is not going to be short so that wont be a problem, I was just worried about the diameter.
Old Aug 13, 2009 | 06:10 PM
ashb82's Avatar
your welds are you sure you have the + and - wires correct i have a good lincoln welder that was flux core then i switch to gas but did not swap the +and - it looked look your welds now it looks good i am even proud to show off my welds
Old Aug 13, 2009 | 06:44 PM
haas480's Avatar
sorry for thread jackin here, but to ashb82. its all hooked up right. thats not even fluxcore wire, haha, i just ran out of gas. i can weld a decent bead and would show it off. but that day busted my ***** for sure.
Old Aug 17, 2009 | 11:10 AM
kte324's Avatar
I guess I am going to run 4". Just not sure if I want to run it out the right side of the bumper or by the firewall.
Old Aug 17, 2009 | 12:42 PM
haas480's Avatar
if possible, i suggest run it out the side man. when its anywhere under the car, the fumes are pretty intense. especially a nice rich race setup with alot of hp. doesn't make it super enjoyable for daily drivin or any drivin really, unless its just a quick pass. gl.
Old Aug 17, 2009 | 02:04 PM
kte324's Avatar
Well where I live we got some pretty loud street driven cars so mine shouldn't be a problem. Cops dont really mind. I am just don't want my car covered in black stuff.
Old Aug 17, 2009 | 02:26 PM
haas480's Avatar
yea. everything i own is straight pipe or just downpipe. didn't think about it gettin all over your car. but you will def smell it and it can get you too, being pretty strong, if it stops at the firewall or anywhere where it can seep into the cab.
Old Aug 17, 2009 | 06:23 PM
jnv255's Avatar
My 4in exhaust coming out the side, isn't as loud as my 3in that ran the length of the car.. I would run a 3in with your setup. The only reason I have a 4in is because my turbo is a 372.. With my 67mm I had 3in
Old Aug 18, 2009 | 05:11 AM
kte324's Avatar
Well I have had a full 3" exhaust and I am just trying to do something different, as long as it is not hurting my performance I don't mind it.
Old Aug 18, 2009 | 05:54 AM
AJxr's Avatar
im thinking because it looks like an ebay ramhorn, having thin runners and all.
Old Aug 18, 2009 | 07:28 AM
haas480's Avatar
yea. its an ebay ram horn. but its thick and its braced. not going to fall apart.
jdmboy94
Apr 6, 2009 04:46 PM
h22sedan
Jan 8, 2007 05:34 AM
JDM_EH2
Aug 24, 2005 05:34 PM
SiRkid
May 11, 2003 10:22 PM
project dc2
Mar 1, 2003 05:22 AM
