Is 4" Exhaust overkill on my current setup?
Old Aug 15, 2007 | 08:08 PM
96 GSR-T's Avatar
Default Is 4" Exhaust overkill on my current setup?
I found a buyer that is going to pay good money for my Thermal, and I will be upgrading to a dual gate T4 setup next year with a new bottom end, my question is will the 4" hurt my current setup as far as power and responce? I do not know if the 4" is too much for what the car currently is, I dont want to go to the tuner and have him say you should of kept the 3" on.
Neukin EL
GE Sleeded 81.5mm
Wiseco/Crower Pro
Tial 44mm
Tial 50mm
Victor X w/ 70mm TB
2.5" Charge Piping
All Ferrea w/ .5mm Oversize
3" DP
T67 H.O. to a 3" DP
Running E85 as Primary Fuel (500-600 whp all day)
Plan on just welding a 3-4" increaser on the DP for now until its time for a true 4" DP w/ the Topmount.....
Old Aug 15, 2007 | 08:24 PM
s2kdre's Avatar
Default Re: Is 4" Exhaust overkill on my current setup? (96 GSR-T)
do u have a .63 hot side now? if so then that turbo isnt big enough to flow for the 4 inch.
gritsak's Avatar
I dont see it hurting response to your current setup, that turbo provides plenty of backpressure to the engine. Doubt you will see any sig. power gains though.
Old Aug 15, 2007 | 08:27 PM
s2kdre's Avatar
Default Re: Is 4" Exhaust overkill on my current setup? (gritsak)
i was using a pt74 on my supra, with a .81 hotside with a full 4 inch all the way back.
Old Aug 16, 2007 | 04:04 AM
96 GSR-T's Avatar
Default Re: Is 4" Exhaust overkill on my current setup? (s2kdre)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by s2kdre &raquo;</TD></TR><TR><TD CLASS="quote">i was using a pt74 on my supra, with a .81 hotside with a full 4 inch all the way back.</TD></TR></TABLE>
this isnt a PT74, irrevelant
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by s2kdre &raquo;</TD></TR><TR><TD CLASS="quote">do u have a .63 hot side now? if so then that turbo isnt big enough to flow for the 4 inch.</TD></TR></TABLE>
.82 P-Trim, using same turbo next year but with T4 housing instead
Old Aug 16, 2007 | 04:18 AM
DCxMagus's Avatar
if your around 600whp with that turbo, I would say your pretty close to maxing that 3 inch, it should be safe to go to a 4 inch exhaust.
YoungKadafi
Oct 17, 2006 11:35 AM
fastcivicboy
Apr 7, 2005 08:40 AM
tonezilla
Jan 17, 2004 09:33 PM
Serdar
Nov 18, 2003 06:26 AM
Sh4rky
Feb 9, 2002 08:36 AM
