3bar Map Problems!
I just installed my 3 bar map sensor and drove my car and it ran like crap. I check the volts and I got a 2.2volts. Hondata said I should get a 1.6. Anyone have a clue to why I'm having this problem?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by FIxALPHA »</TD></TR><TR><TD CLASS="quote">Make sure that your ecu is chiped for a 3 bar map sensor</TD></TR></TABLE>
Yes it is.
Yes it is.
where did you get your 3 bar map? are you sure it is a 3 bar? you can check to see how high you have to pressurize it to make the voltage output go to 5 volts
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by intekragsr »</TD></TR><TR><TD CLASS="quote">are you using hondata?</TD></TR></TABLE>
no, but that shouldn't matter
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Spunkster »</TD></TR><TR><TD CLASS="quote">Then what are you using that allows the use of a 3-Bar?</TD></TR></TABLE>
I've been sworn to secrecy.
Can someone help me???
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by intekragsr »</TD></TR><TR><TD CLASS="quote">how the hell are we supposed to help you when you wont tell me what stand alone you are using? and you are sworn to some secrecy crap. </TD></TR></TABLE>
Can you tell me how the ECU would effect the voltage of the map sensor? Keep in mind the stock stock map has correct voltage.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by The Crow »</TD></TR><TR><TD CLASS="quote">
Can you tell me how the ECU would effect the voltage of the map sensor? Keep in mind the stock stock map has correct voltage.</TD></TR></TABLE>
Look, if the voltage coming out of the MAP sensor is 2.2 when it should be 1.6 it's obvious the sensor is the problem. Either the wiring is jacked up (5v source, not 12v, right?) or your sensor is busted or the wrong one. If you can't share your big-*** secret
then I doubt anyone can help any further.
Just check the wiring and it's fine and I just tried a GN map and it reads 2.3volts. It's great to have friends with nice cars.
I need my 18psi!
I need my 18psi!
