Is this a 3bar or 2 bar sensor (voltages inside)
Old Apr 2, 2003 | 05:13 PM
niedejb's Avatar
Default Is this a 3bar or 2 bar sensor (voltages inside)
Got my new map sensor installed tonight but have a question:
Are the following voltages representative of a 2 or a 3 bar sensor?
1.6V = Atmosphere
2.2V = 5 psi
2.6V = 10 psi
3.2V = 15 psi
3.7V = 20 psi
4.2V = 25 psi
4.8V = 30 psi
5.0V = 32 psi
This was verified on two different pressure gauges.
The part number on the sensor is 16040749.
I was always under the assumption that a 3bar sensor should max its voltage out at 3 bar (45psi). Or does it consider the vacuum range as one of the "bars"?
Not really worried about it, but wanted to get everyones input.
Old Apr 2, 2003 | 05:18 PM
intekragsr's Avatar
Default Re: Is this a 3bar or 2 bar sensor (niedejb)
interested in this too......bump
Old Apr 2, 2003 | 05:30 PM
QHP's Avatar
QHP
Default Re: Is this a 3bar or 2 bar sensor (intekragsr)
base on the number it should be a 3bar map sensor
Old Apr 2, 2003 | 05:43 PM
niedejb's Avatar
Default Re: Is this a 3bar or 2 bar sensor (QHP)
Guess thats why hondata's sight says
"By using a GM 3 bar MAP sensor boost up to 28 lbs can be read"
Just kinda strange since 28 psi is ~ 2 bar.
Old Apr 2, 2003 | 08:35 PM
racerxadam's Avatar
the full range of the sensor measures 3 bars. one of vacuum and two pressure
Old Apr 2, 2003 | 09:36 PM
Joseph Davis's Avatar
Default Re: Is this a 3bar or 2 bar sensor (racerxadam)
29 psi is two bar.
The GM sensor is apparently +/- 3% or so, causing readingds above 29 psi. You're also using a service grade vacuum/pressure gauge, so I doubt it's a highly calibrated instrument.
Old Apr 2, 2003 | 09:43 PM
Speed PHreak's Avatar
Default Re: Is this a 3bar or 2 bar sensor (J. Davis)
It's a 3 bar, enjoy.
Old Apr 2, 2003 | 09:52 PM
accordfreak's Avatar
Default Re: Is this a 3bar or 2 bar sensor (Speed PHreak)
hey niedejb, which color is the map signal wire? is it the yellow and white?
what about the 5 volts wire??
i took the voltage of each wire 1st wire is 5.2 volts, 2nd wire is 4.8 volts, and the 3rd is .3 volts, so is the 4.8volts wire the signal wire?
Old Apr 3, 2003 | 02:16 AM
niedejb's Avatar
Default Re: Is this a 3bar or 2 bar sensor (accordfreak)
Use the wiring from here:
http://hondata.com/3barinstall.html
Colors matched up.
insaneconceptz
Mar 4, 2009 05:35 AM
b16boy95
Nov 28, 2008 09:33 PM
weiRtech
Feb 26, 2006 12:39 PM
Btothe3rdDegree
Jul 13, 2004 10:49 AM
Beer
Jun 19, 2002 11:44 PM
