-3an to small for t3/t4?
Old Jul 9, 2003 | 10:16 AM
88crxvtec's Avatar
Default -3an to small for t3/t4?
just got my turbo rebuilt, they said the -3 line was to small I needed a -4. Anyone have thoughts on this?
Old Jul 9, 2003 | 12:54 PM
DRAGLS's Avatar
Default Re: -3an to small for t3/t4? (88crxvtec)
its to small i have gone thru 4 turbo in 8 months
Old Jul 9, 2003 | 12:55 PM
b18bturbo's Avatar
Default Re: -3an to small for t3/t4? (DRAGLS)
-3 is fine ask Flamenco-t and many others -3 is optimum choice for turbos
Old Jul 9, 2003 | 01:24 PM
DirtyLude's Avatar
Default Re: -3an to small for t3/t4? (b18bturbo)
-3 is perfect.
Old Jul 9, 2003 | 02:42 PM
spoolinlude's Avatar
I live under a rock
Default Re: -3an to small for t3/t4? (DirtyLude)
i use -12...... depends on what kind of power you plan to make
Old Jul 9, 2003 | 02:45 PM
Mase's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b18bturbo &raquo;</TD></TR><TR><TD CLASS="quote">-3 is fine ask Flamenco-t and many others -3 is optimum choice for turbos </TD></TR></TABLE>
i agree, ive used -3 on two different turbo setups w/ my car, and its perfect
Old Jul 9, 2003 | 02:48 PM
ahobbs's Avatar
HELLO,GOOD MORNIN'
Default Re: -3an to small for t3/t4? (spoolinlude)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by spoolinlude &raquo;</TD></TR><TR><TD CLASS="quote">i use -12...... depends on what kind of power you plan to make</TD></TR></TABLE>
Hopefully your talking about return.
Old Jul 9, 2003 | 02:50 PM
ahobbs's Avatar
HELLO,GOOD MORNIN'
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DirtyLude &raquo;</TD></TR><TR><TD CLASS="quote">-3 is perfect.</TD></TR></TABLE>
I understand the -3 seems to be the right size for hondas..........but why? I have a 3-3 but i want to know why is it so perfect. Don't want to much flow?
Old Jul 9, 2003 | 02:54 PM
shortyz's Avatar
Default Re: -3an to small for t3/t4? (HybridcivicLS-T)
-3 is fine..
we deal with high oil pressure 50-60. that couldl be the cause of blowing seals, 50psi is pushing a turbo seal.
with pressure that high it shoots a lot of oil through.
Old Jul 9, 2003 | 03:12 PM
88crxvtec's Avatar
Default Re: -3an to small for t3/t4? (shortyz)
they said they won't warranty it if I don't chance the feed size, should I call and tell them honda makes high oil pressure??
Old Jul 9, 2003 | 05:13 PM
Flamenco-T's Avatar
I have been using -3AN on all my setup and I have had a lot of customers with my feed line kit and I have not heard of any problem as of yet. But yeah honda have a constant high pressure from the block and I don't foresee any problem with a -3An line. I do have a few customers who came to me with a blown turbo using -4AN line and I ended up replacing them with -3AN lines.
stan
Old Jul 10, 2003 | 08:57 AM
ahobbs's Avatar
HELLO,GOOD MORNIN'
Default Re: -3an to small for t3/t4? (Flamenco-T)
thanks stan
Old Jul 10, 2003 | 10:56 AM
B18c1turboedEK's Avatar
So is 4-AN to big then ??? IM building my own kit and thats what i got was a 4-An let me know PLease
Old Jul 10, 2003 | 03:42 PM
shermanyang's Avatar
Default Re: -3an to small for t3/t4? (Koticcivic4u)
i used a -3an from the block to a tee fitting from there i used another -3an line to the turbo and blew my turbo at high rpms. changed to a -4 from the tee and everything's been fine since.
Old Jul 10, 2003 | 05:25 PM
I live under a rock
Default Re: -3an to small for t3/t4? (shermanyang)
o yea...... sorry..... it was a long day yesterday
Old Jul 10, 2003 | 05:40 PM
tony1's Avatar
I use -3 on all the kits i build. If you are having problems then it's most likely a problem on the return side of things. Either not completely gravity fed or a kink in the hose. -3 line is NOT the problem...
Old Jul 10, 2003 | 05:55 PM
turbolshatch's Avatar
Default Re: -3an to small for t3/t4? (tony1)
-3 is the recommended size for a oil feed line
Old Jul 10, 2003 | 06:50 PM
88crxvtec's Avatar
Default Re: -3an to small for t3/t4? (turbolshatch)
thanks guys, I'm running the 3 and I have the braided -10 return line, it had a slight kink where it hit the crossmember ( CRX) so I redid it so it didn't touch. Started the car up tonight and works great. That and my JDM Blitz super sound BOV and the damn car sounds like a Supra! lol
cleanej2
Oct 20, 2008 03:56 PM
dumas07
Jul 17, 2006 05:18 PM
kcjohnnyboy
Jan 25, 2006 10:58 AM
Topdawgg
Jan 23, 2006 06:54 PM
2point2
Welding / Fabrication
Oct 11, 2004 08:09 AM
