3an feed line question
Old Jul 19, 2006 | 12:31 PM
tcontesh's Avatar
Default 3an feed line question
im running a 3an feed line from the back of the block where the oil pump is located. im having issues with no power after 5k rpms like a dead spot, it revs to redline fine but no power. would an oil restrictor help
thanks
Old Jul 19, 2006 | 12:35 PM
RTW DC2R's Avatar
this doesnt exactly sound like an oil related issue unless vtec isnt engaging. what makes you think the problem is related to lack of oil restrictor? oil restrictors just restrict oil feed pressure to the turbo. if it had anything to do with lack of oil pressure, and you are revving to redline, your asking for trouble.
Old Jul 19, 2006 | 01:18 PM
tcontesh's Avatar
Default Re: (RTW DC2R)
yes vtec isnt engaging and everything else has been done except the oil restrictor.
i have tried multiple ecus and wiring harnesses. and becasue the oil feed is off of the pump we figured alot of the pressure is going to the turbo and not enough to the vtec solenoid.
Old Jul 19, 2006 | 01:38 PM
RTW DC2R's Avatar
hook up an oil pressure gauge off the back of the block in the stock location. Or disconnect the injector clips and plugs, turn the car over, see if you get oil on the cams. If you do then you have atleast some pressure. I would think that unless there was a big gaping hole in the oil system somewhere, the block/head would still get pressurized and have enough oil pressure to engage vtec.
Old Jul 19, 2006 | 01:58 PM
tcontesh's Avatar
yeah i think im just going to put the oil restictor in for now just to see if that helps.
if it doesnt, any other suggestions? the oil level stays full between oil changes.
Old Jul 19, 2006 | 03:01 PM
RTW DC2R's Avatar
was it working properly before? has something changed since then? maybe try another vtec solenoid?
Old Jul 19, 2006 | 07:19 PM
tcontesh's Avatar
yep the vtec worked great before the turbo setup, vtec solenoid had been tested and works good that is why i have resorted to the oil restrictor.
have you heard of any similar problems after turbo installs on vtec cars?
Old Jul 19, 2006 | 07:25 PM
tcontesh's Avatar
Default Re: (tcontesh)
has anyone ever had issues on h22s or b18s
where is the most common place for oil feed lines?
Old Jul 19, 2006 | 09:09 PM
rebo0t's Avatar
i think you should get oil from the back of the block.
Old Jul 20, 2006 | 03:58 AM
PrecisionH23a's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tcontesh &raquo;</TD></TR><TR><TD CLASS="quote">has anyone ever had issues on h22s or b18s
where is the most common place for oil feed lines?</TD></TR></TABLE>
I've never had issues before. The best place is to tee into where the oil pressure sensor is on the back of the block (below the oil filter).
Old Jul 20, 2006 | 08:05 PM
tcontesh's Avatar
Default Re: (PrecisionH23a)
should i just give the oil restrictor a shot cause i can hear vtec but its really weak and its not making any power
also should my car make a noticable difference in vtec?
tcontesh
Jun 29, 2006 01:46 PM
BoostedVtecGsr
Nov 15, 2004 09:20 AM
wade
Oct 10, 2004 07:38 PM
newstyd
Jun 16, 2003 10:56 AM
