350whp from 6psi on LS/VTEC?
Old Jun 16, 2003 | 11:33 AM
B18C5-EH2's Avatar
Former Moderator
Loved
Default 350whp from 6psi on LS/VTEC?
I have a good friend that says that one of his friends supposedly laid down 350whp on just 6psi of boost on a fully built LS/VTEC engine.
Enigine has AEM EMS, JG head, JG intake manifold, 84.5mm bore low CR pistons, etc.
I have no idea on specs for the turbo, sorry.
I told him I just don't think it is possible. *Maybe* with on-the-edge-tuning and race gas?
Thoughts?
Old Jun 16, 2003 | 11:35 AM
GreddySi99's Avatar
Default Re: 350whp from 6psi on LS/VTEC? (B18C5-EH2)
it is possible
Old Jun 16, 2003 | 11:37 AM
DIY_Racing's Avatar
Well, first off anything is possible..
But, no that does not sound feasible... Say he built the motor high compression and had it at 220 ish to the wheels.. then put a turbo on and added a bunch more fuel and boosted 6psi. I dont think you can get over 20hp per 1 psi of boost.. i just dont think thats feasible.. under three hundrred MAYBe... 280 MAYBE. more like 260 ish or so...
but, who knows.
Old Jun 16, 2003 | 11:39 AM
-iLLuZioN-B18C1's Avatar
Default Re: 350whp from 6psi on LS/VTEC? (DIY_Racing)
i highly doubt it as well, but who knows.
Old Jun 16, 2003 | 11:41 AM
civperc's Avatar
hmm, that does sound kinda high, I'd say 250 and below would be believeable. does he have a dyno plot?
Old Jun 16, 2003 | 11:46 AM
B18C5-EH2's Avatar
Former Moderator
Loved
They are supposed to be lower CR, so again I too was thinking no way.
A friend of mine with a fully built B18C1 is pushing 350whp on 15psi of boost with pump gas with AEM EMS and 11.8:1 A/F ratios.
He concurred that he diesn't believe it at all.
Old Jun 16, 2003 | 11:51 AM
quikB18B's Avatar
You see b18c5 making close to 300 on 6.5-7 psi, but again u say hes runnign low compression so i would say Nope. Ask himn for a dyno sheet and that should answer your ? ummm ummm i lost it. you get my point.
Old Jun 16, 2003 | 12:04 PM
madman604's Avatar
*cough*bullshit*cough*
Old Jun 16, 2003 | 12:14 PM
DIRep972's Avatar
Smarter than you
A local guy here turned out 372whp/231 tq @ 9psi on his 10:1 GSR motor- 83mm bore, SC61 turbo. he had conservative tuning, pump gas, and a stock GSR head(only upgrade valvesprings/retainers)
With head work, OS valves, Extra displacement from the LS stroke/84.5mm bore and more aggressive tuning I definitly see it being possible.
Ultimatly it depends on what size turbo he is running, do u happen to know or can u find out?
Old Jun 16, 2003 | 12:35 PM
AVATAR's Avatar
Default Re: 350whp from 6psi on LS/VTEC? (DIRep)
Maybe he's running a T88-34D
Old Jun 16, 2003 | 12:38 PM
b18cx's Avatar
Default Re: 350whp from 6psi on LS/VTEC? (AVATAR)
Flywheel numbers maybe?????
If thats the case, Then my stock B16A in my 00 SI dyno'ed 290hp at 6.5psi. Would be nice to say but not real honest.
Old Jun 16, 2003 | 11:26 PM
jdmsiR20's Avatar
Default Re: 350whp from 6psi on LS/VTEC? (b18cx)
possible, but IMHO not probable... BUT... the AEM EMS does wonders! wonderful tuning capablities, maybe toooo much!
Old Jun 16, 2003 | 11:58 PM
AbaZ's Avatar
Default Re: 350whp from 6psi on LS/VTEC? (jdmsiR20)
I made 270whp on my stock ls/vtec @ 12psi
Edlebrock intake/Zdyne SECU, yada yada...
I guess 350 could be possible, but at 6psi? who runs 6psi these days,
Old Jun 17, 2003 | 01:11 AM
Tofurky's Avatar
Default Re: 350whp from 6psi on LS/VTEC? (AbaZ)
maybe... but 6psi is hard to believe.... really hard to believe... big question is, what turbo?
Old Jun 17, 2003 | 01:13 AM
lazerus's Avatar
Default Re: 350whp from 6psi on LS/VTEC? (Ruckus138)
he's forgetting to tell you about the 75 shot of nos he's using... hahaha
Old Jun 17, 2003 | 05:12 AM
GreddySi99's Avatar
Default Re: 350whp from 6psi on LS/VTEC? (lazerus)
Well thats what I was thinking. a hugely gross sized turbo and a undrivable car track only a t-100 thumper series that spooled 6psi at 7600RPM and maybe it would do it. just my thoughts
Old Jun 17, 2003 | 06:24 PM
wespirl's Avatar
Default Re: 350whp from 6psi on LS/VTEC? (intercooledJRSC)
was getting 270 out of my stock LS @ 10psi, haven't dynoe'd it again since it's been built. Built LS/Vtec.... it is possible but definately not at 6 psi
bigmike305
Sep 29, 2009 04:15 PM
EGgarniEG
Apr 22, 2008 04:43 PM
Dc2 Joe
Jan 21, 2006 09:54 AM
DriveSlowHomie
Jan 26, 2005 08:59 AM
rondigs
Nov 13, 2001 08:43 AM
