Anyone boosting LS/VTEC
Old Nov 8, 2001 | 07:23 PM
rondigs's Avatar
Default Anyone boosting LS/VTEC
First off- Don't respond if your hating... We've heard it all before.
Im building my LS/VTEC from ground up, NO SHORT CUTS and Im wondering:
what compression pistons to use for 10-12 lbs of boost. Im sure putting the different head on will change the compression, so thats a factor... But how can you be sure about the ideal ratio???
I plan on running it N/A for the first couple months, then put the boost to it after it feels all nice and cozy in its new home...
<U></U> <U></U> <U></U> <U></U>
Old Nov 8, 2001 | 11:18 PM
Gmedalion's Avatar
Default Re: Anyone boosting LS/VTEC (rondigs)
https://honda-tech.com/zerothread?id=86745
Old Nov 8, 2001 | 11:53 PM
Incognito's Avatar
Default Re: Anyone boosting LS/VTEC (Gmedalion)
Yeah, go click the link above. I hear that guy's turbo LS/VTEC runs 11.4's or something. hehe
Old Nov 9, 2001 | 08:48 AM
rondigs's Avatar
Default Re: Anyone boosting LS/VTEC (Incognito)
People quit giving their "constructive" critisism when they find that people can actually pull off some good stuff with the setup. And theres more to come(less bugs in the system after a little tuning)...
You didn't list any info for compression ratios. And I assume that the car is a daily driver? Also, why haven't you done any adjustments to the ECU- that can really make a difference...
Old Nov 9, 2001 | 09:49 AM
mr2's Avatar
mr2
sdamnnnnnnnnn 11.4 :] sweet
Old Nov 13, 2001 | 08:28 AM
Incognito's Avatar
Turbo LS/VTEC works.
CR is 9.2:1, which is about what GSR head on LS block gives.
Stock ECU w/VAFC, 370cc injectors.
Old Nov 13, 2001 | 08:32 AM
InfamousDX's Avatar
a simple piggyback like a v-afc will suffice with larger injectors (i have 370's too) if you're a good tuner.
Old Nov 13, 2001 | 08:43 AM
rtype11's Avatar
ever tried building a vtec ls?
use GSR block, ls crank, internals head ..., this will give you a torquey motor with good head valvetrain and oil squirters, you can ugrade any of the rods and pistons to whatever CR you want. all you lose is about 60cc of displacement. this will be a high revving ls.
Joelz-Santana
Mar 11, 2009 04:53 PM
olskoolhatchy
May 7, 2008 12:56 AM
olskoolhatchy
May 6, 2008 03:28 PM
torr
Feb 3, 2003 04:22 AM
