ls built
Old Oct 18, 2007 | 06:55 AM
EGgarniEG's Avatar
Default ls built
is there a nice steup to make an ls quick? rather than going ls vtec.
Modified by EGgarniEG at 8:54 AM 10/18/2007
Old Oct 18, 2007 | 07:08 AM
Dogginator's Avatar
Daisy... Daisy...
Default Re: ls built (EGgarniEG)
Btw: It is spelled VTEC.
Turbo works well with an LS.
Old Oct 18, 2007 | 07:56 AM
EGgarniEG's Avatar
thanks microsoft spellcheck
Old Oct 19, 2007 | 05:03 AM
EGgarniEG's Avatar
HELP OUT A noob
Old Oct 19, 2007 | 05:24 AM
Lithel's Avatar
I would like to know too...
Old Oct 19, 2007 | 06:26 AM
evildc2's Avatar
no matter how you look at you gonna have to put $ in it if you dont want vtec
ther other things you can do, a major engine tunning like higher compression pistons, a larger bore, high lifting cams(poor idle quality),bored out throtle body,
or maybe a turbo set up or nos, all depends on your budget and or what you want but i'm sure you'll end up going vtec.
Old Oct 19, 2007 | 06:28 AM
Byaaah!'s Avatar
Jet Life Til' The Next Life
Default Re: ls built (evildc2)
Boost works really good with an LS, thats what I would go for...
Old Oct 19, 2007 | 07:46 AM
91redteg's Avatar
Default Re: ls built (Project 95LS-VTEC:No More)
boost is best for an ls. i just finisghed my rebuild now waiting for a tune. then i can start building my boost setup
Old Oct 19, 2007 | 10:01 AM
K2sInteg98's Avatar
Default Re: ls built (91redteg)
yeah the best thing to do with your ls is boost, thats the only way to get real power out of it. If you wanna stay all motor, just swap the motor because you said you dont wanna do ls/vtec. An all motor ls is a waste of money.
Old Oct 19, 2007 | 11:38 AM
Acuronda_SloTeg's Avatar
I beg to differ on the waste of money comment! my ls runs with the big boys all day. i got some boltons, slight internals and hondata and shes doin great!
Old Oct 19, 2007 | 11:42 AM
kartman5's Avatar
My son went with a LS build and it runs great. Dynoed at 163 whp and 130 torque with a crappy header and stock TB. Engine rebuilt with ITR pistons and rings with a .020 overbore. Full head with Crower 404 cams. All bolt ons, I/H/E. Runs great and is fast. You may want to consider something like this. With a CAI, larger
TB and a good header, I think it might pull 175 hp or more.
Old Oct 19, 2007 | 11:44 AM
Case Closed lol. i like that build tho. im goin N/A LS
Old Oct 19, 2007 | 11:45 AM
W/o VTEC
Old Oct 19, 2007 | 11:49 AM
PLAGUED_DB7's Avatar
What are your Dyno #'s?
You drop $$$$$, and end up "hanging" with the big boys.
On the flip side if you boosted you would be smoking the big boys... This topic has been discussed over, and over again.
It takes quite of bit to get an LS to STOCK GSR Dyno #'s
Doin great eh?
https://honda-tech.com/zerothread/2129507
Old Oct 19, 2007 | 11:56 AM
actually yea i am doin good. odd enuff the motor has 239k on it. belt shud snap. tell me im not doin good with an old crusty motor hangin with vtec engines.and yea im hangin. i beat quite a few and lose to some by a little and everyone where i live is boostin. i wants to be unique and everyone respects it and especially respects my car for how well it runs. and yes its discussed and yea i would love to boost or spray. but im the kind that will take the biggest challenge out there.
Old Oct 19, 2007 | 12:03 PM
EGgarniEG's Avatar
wats a good turbo setup for 250whp
Old Oct 19, 2007 | 12:11 PM
CeReal's Avatar
Default Re: (PLAGUED_DB7)
zooming out. you can get lighter parts. if you can remove 300 lbs worth, well, ive done a calculation and it comes out to 25hp. well actually more like 24.87hp but whos counting.
Old Oct 19, 2007 | 02:49 PM
yarara0825's Avatar
Default Re: (EGgarniEG)
get a t3/t4 turbonetics if your gonna go boost!
nos !!!
but if you wanna build it then you goin to have to spent a lot of money either way u goin to need :
higher compresion
ported the head
cams
cam gears
pistons
etc..
thats what i, going for built an ls and be respected on street getting beat by me with no vtec
Old Oct 19, 2007 | 03:49 PM
b20powereDA's Avatar
Default Re: (yarara0825)
i love the integra forum. i feel like a genius in here. all these random comments with absolutely no knowledge. (sarcasm intended)
just out of curiosity, why exactly is it that the t3/t4 should be the turbo that he picks? out of all the different turbo sizes the t3/t4 is optimal? do u know what kind of build he is going with that is going to make the t3/t4 the best turbo for him? do u know where he is gonna want to make the most power and what kind of power? u must know something that i dont
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CeReal &raquo;</TD></TR><TR><TD CLASS="quote">zooming out. you can get lighter parts. if you can remove 300 lbs worth, well, ive done a calculation and it comes out to 25hp. well actually more like 24.87hp but whos counting.</TD></TR></TABLE>
and WTF?!?! wieght translates to horsepower now? i understand that it will make the car faster but u dont wanna tell a noob that if u shed 300 lbs. it will add 25 hp. and also, how did u calculate this exactly?
Old Oct 19, 2007 | 03:53 PM
but to the OP, im gonna answer ur original question. u asked: <TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EGgarniEG &raquo;</TD></TR><TR><TD CLASS="quote">is there a nice steup to make an ls quick? rather than going ls vtec.
Modified by EGgarniEG at 8:54 AM 10/18/2007</TD></TR></TABLE>
and yes their is alot of thing that can be done to an ls to make it pretty quick. most people are going to recommend turbo because that is the most cost effective way to make power out of a ls. but if u jus want a fairly quick reliable daily driver i would recommend some bolt ons of course (i/h/e), either crower 403's or 404's depending on what pistons u choose to go with. and some b16 or itr pistons. a nice clutch and flywheel upgrade and this car should keep u fairly satisfied for a little while. but dont forget to TUNE! TUNE! TUNE! TUNE!
Old Oct 19, 2007 | 05:42 PM
I like that. consistency with that build. genius. i like n/a but im sure my next motor will be spoolin a snail
Old Oct 19, 2007 | 06:02 PM
Dogginator's Avatar
Daisy... Daisy...
Default Re: (b20powereDA)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b20powereDA &raquo;</TD></TR><TR><TD CLASS="quote">and WTF?!?! wieght translates to horsepower now?</TD></TR></TABLE>
I agree. I have seen people dyno higher with a lighter flywheel due to the fact that the dyno is accelerating and the reduced rotational inertia is misinterpreted as power in that case.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b20powereDA &raquo;</TD></TR><TR><TD CLASS="quote">and yes their is alot of thing that can be done to an ls to make it pretty quick. most people are going to recommend turbo because that is the most cost effective way to make power out of a ls. but if u jus want a fairly quick reliable daily driver i would recommend some bolt ons of course (i/h/e), either crower 403's or 404's depending on what pistons u choose to go with. and some b16 or itr pistons. a nice clutch and flywheel upgrade and this car should keep u fairly satisfied for a little while. but dont forget to TUNE! TUNE! TUNE! TUNE!</TD></TR></TABLE>
You can apply moderate boost to keep reliability and produce reasonable HP.
Old Oct 19, 2007 | 06:15 PM
integrals21's Avatar
Default Re: (Dogginator)
i would go with boost...if you want a fast ls...do some research...and pic your own turbo kit...works great...
Old Oct 20, 2007 | 06:44 AM
EGgarniEG's Avatar
thanks alo b20 i had a ? how much for a all those parts to go fairly quick approx
Old Oct 20, 2007 | 05:53 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dogginator &raquo;</TD></TR><TR><TD CLASS="quote">
You can apply moderate boost to keep reliability and produce reasonable HP.</TD></TR></TABLE>
ive seen it also, but thats a flywheel. not like gutting the car.
and i agree on the moderate boost but im just giving him another option, since everyone always says boost it. and if u go with moderate boost chances are eventually u will get tempted and crank up the boost and bad things begin to happen. u cant just make a cam lift higher for longer period of time at the press of a button
