350 whp ls
Old Jun 9, 2004 | 08:36 AM
turbo89civicb18hatch's Avatar
Default 350 whp ls
wat would i have to do to an ls to make 350 whp ls, how much boost, wat to do to the bottom end, wat kind of fuel management.
i have a stock ls 9 psi and i want to make more power i have dsm 440s w. safc for fuel.
Old Jun 9, 2004 | 08:38 AM
kaptr1d's Avatar
Default Re: 350 whp ls (turbo89civicb18hatch)
hmmmm. alot?
pm hoosierdaddy. he has an ls that is capable of making 350whp but he has the boost turned down.
Old Jun 9, 2004 | 08:43 AM
JDMH22HATCH's Avatar
Definitely get rid of the SAFC and 440's and invest in Hondata or some form of fuel management. What size turbo are you running as well? There are a few stock LS's down here making close to 350 with stock motor.
Old Jun 9, 2004 | 08:45 AM
Default Re: 350 whp ls (JDMH22HATCH)
t3-60 turbo
Old Jun 9, 2004 | 08:49 AM
ORcivicsi's Avatar
As said before. Engine managment and tuning (good tuner).
Old Jun 9, 2004 | 08:55 AM
quikB18B's Avatar
Default Re: 350 whp ls (ORcivicsi)
If it were me heres what I would do
Forged Pistons/Rods, fresh rebuild, hondata or another good fuel setup, bigger injectors(that what you have), good tuner, SC61 and 17-18 psi should do the trick.
You might, and let me say might do it with a stock motor, but if it happened I wouldnt anticipate it lasting very long.
Modified by quikB18B at 12:31 PM 6/9/2004
Old Jun 9, 2004 | 09:09 AM
Boltz's Avatar
the 60 trim t3 wont provide close to enough flow for that much power.
Old Jun 9, 2004 | 10:36 AM
EpDarks's Avatar
Default Re: 350 whp ls (Boltz)
Yeah that t3 aint gonna cut it.
I'd say you'd be safe with a t3/t4, Hondata, tuning.
Post the rest of your setup so we know if there are any other weak points.
Old Jun 9, 2004 | 01:47 PM
Rod.'s Avatar
Default Re: 350 whp ls (EpDarks)
I think b18bek making 350 or real close to it on a stock ls
Old Jun 9, 2004 | 03:38 PM
DENCIO's Avatar
Default Re: 350 whp ls (redturbocivic)
I'm in the same boat as this guy...is t3/t4 .63ar 57 trim .60ar good enough for 350whp???
Old Jun 9, 2004 | 03:45 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by redturbocivic &raquo;</TD></TR><TR><TD CLASS="quote">I think b18bek making 350 or real close to it on a stock ls</TD></TR></TABLE>
Conor made 327 on stock ls with skunk2 mani, and little ****. That was at 12.5 lbs or so on the XS TO4X
Slammedteggy01
Dec 5, 2012 03:31 PM
lsvtechatch92
Aug 2, 2007 08:12 PM
killablaze
Nov 16, 2005 07:25 AM
Jdm_Rice_Monster
Nov 6, 2003 10:54 AM
sonicSVT
Jan 29, 2003 08:37 AM
