310cc Injectors - what is needed?????????
Old Nov 20, 2002 | 09:14 AM
TURBOED-TEG's Avatar
Default Fuel Setup?????????
Currently I am running a 12:1 FMU with a inline fuel pump and stock injectors. How big of injectors can the stock ecu handle and what about the 12:1 fmu should I get a different disc?
[Modified by TURBOED-TEG, 7:13 PM 11/20/2002]
Old Nov 20, 2002 | 10:13 AM
Default Re: Fuel Setup????????? (TURBOED-TEG)
ttt
Old Nov 20, 2002 | 10:37 AM
b18b98's Avatar
Its recommended to use a 8:1 fmu disk with 310s. It should idle fine but if you want, you can always put in a SAFC.
Old Nov 20, 2002 | 11:08 AM
Default Re: Fuel Setup????????? (b18b98)
I guess I should give you some background - I have a DRAG 3 kit, AEM fuel rail and S-AFC. So 310cc and 8:1 huh? ok
Old Nov 20, 2002 | 12:07 PM
01ITR#700's Avatar
I've been doing the same research and your correct, go with an 8:1 FMU with 310's.
Old Nov 20, 2002 | 12:10 PM
dc r-spec's Avatar
Default Re: Fuel Setup????????? (01ITR#700)
i'm going to be running the 8:1 with 370's and a SAFC, it should be running good however, i do know people who have run 310's with a 12:1 disk and been fine with idle, just slightly off, remember good tuning is key
So can I buy just the 8:1 disk...and what size injectors are in a Prelude? Can I swap OEM injectors from another car over besides the dsm-AFC-hack bullshit.
As soon as I do my automatic - manual swap I will be putting it on the dyno. I pretty much have unlimited use! free heheh
[Modified by TURBOED-TEG, 9:12 PM 11/20/2002]
Old Nov 20, 2002 | 02:49 PM
Zenki James's Avatar
4th gen lude injectors are peak and hold so you need to use a resistor pack. The 5th gen are 270cc/min and those would work good as long as you have a OBD-2 car cause the clips are different.
I would recommend picking up a AFC or something either way just so you are sure your not going to throw any codes due to running to rich at low throttle due to the bigger injectors. You can try and lower your fuel pressure but it your idle goes under 32psi your injectors won't fire well enough to provide proper fuel at idle.
The FMU disc will change due to boost amount (need to look at A/F ratio on dyno) but I could run 11psi with a 12:1 disc on my 310s on a B16A2, but fuel pressure at WOT was 110psi.
-James
Old Nov 21, 2002 | 04:25 AM
Default Re: Fuel Setup????????? (Zenki James)
I am OBD2 but plan to change over to OBD1 and the Hondata, so maybe I should just wait for that!
freeplay
Dec 1, 2002 09:41 AM
SIK IN DA HED
Sep 28, 2002 12:57 PM
BoostedD15B7
Sep 26, 2002 01:15 PM
ksoze1688
Sep 8, 2002 03:28 PM
servion
Jan 17, 2002 11:13 AM
