3" intercooler piping?
Old Nov 21, 2011 | 02:55 PM
JDMCIVIC919's Avatar
Default 3" intercooler piping?
I bought a turbo kit from a local friend for my jdm b16. I got a really good deal for it so i couldnt say no. Only problem is that the intercooler piping is all 3" even the outlets on the intercooler are 3". I got a stock b16 with ctr cams and thats it. Im going to run a t3/t4 turbo and only run it on 10psi. Hoping for 300+ will the 3" piping hurt anything? Air pressure? lose hp?
Old Nov 21, 2011 | 03:20 PM
K7-1Ktrevor's Avatar
Loved
Community Favorite
Default Re: 3" intercooler piping?
I doubt it will make much of a difference. 2.5" is ideal with a 2" hot side to reduce lag but you'll be fine.
Old Nov 21, 2011 | 03:27 PM
Yea i read up that my turbo will spool later and thats it. I havnt bought a turbo yet so what turbo will u guys recommend. Its my dd and hoping to make atleast 300whp on 10psi. Its just a jdm b16 with ctr cams.
Old Nov 21, 2011 | 03:28 PM
and also the intercooler is huge!! Its 31x18x3. No loss of hp cuz of that either too or is that different?
Old Nov 21, 2011 | 05:50 PM
welfarepc's Avatar
it will take but the blink of an eye for that volume to be filled.
dont worry about it.
Old Nov 21, 2011 | 07:45 PM
Ok thanks guys and how about that intercooler? no problem either? anyone have pics of that big of a intercooler installed?
Old Nov 21, 2011 | 08:37 PM
Dioxine's Avatar
It shouldnt be a problem. If anything its safe to say that your air wont be hot when it gets to the motor
Old Nov 22, 2011 | 04:04 AM
LS AzZkIkr's Avatar
I would keep what you have. You will be fine. If you don't already have a larger throttle body I would get one that closely matches the size of the piping.
Old Nov 22, 2011 | 02:17 PM
What would be a good tb size? 72mm or 68mm? and people with 96-00 civics can i put the intercooler behind the support bar? Ive seen a couple of civics that did that. Will the 3" intercooler fit behind it? i really dont want to get rid of the support bar.
Old Nov 23, 2011 | 08:40 AM
Schister66's Avatar
Man U FTW
If you're only looking to make 300whp, the 3" piping will actually increase lag and decrease airspeed (in turn, torque) without giving you any actual gains. I would sell it and buy the appropriate 2.5" piping.
If you read through the FAQ, I have a thread detailing the airspeed of a 2.5" vs 3" (and other sizes) and how that affects flow. Ideally, you want the air to move as fast as possible without incurring too much friction along the way. Essentially that means you want the smallest/shortest piping possible unless the piping is becoming a restriction. Again, you can find all this if you want in the FAQ.
rvn2svn
Apr 24, 2014 08:29 PM
95DxSi-R2
Feb 21, 2007 04:55 PM
93_teg_CT
Jun 2, 2006 11:51 PM
asianspeed
Jan 17, 2003 12:23 AM
