3 inch intercooler piping?
Old Aug 1, 2002 | 06:05 AM
internet ay's Avatar
Default 3 inch intercooler piping?
would this be good? i just bought an intercooler and failed to notice that it has a 3 inch inlet and a 3 inch outlet. what are my options, i was hoping to run 2.5 inch piping.
Old Aug 1, 2002 | 07:17 AM
Smashback's Avatar
Default Re: 3 inch intercooler piping? (internet ay)
2.5" piping is probably too big also...my IC has 2.5" in and out so I used silicone reducers to connect 2" in and 2.25" out to it.
Old Aug 1, 2002 | 07:49 AM
b18bturbo's Avatar
Use a reducer.
Old Aug 1, 2002 | 08:31 AM
Default Re: 3 inch intercooler piping? (b18bturbo)
viren would having the 3inch endtanks and using a reducer to a say 2 1/4 have any bad effects performance wise?
Old Aug 1, 2002 | 01:23 PM
ttt
Old Aug 1, 2002 | 01:31 PM
WykidEH's Avatar
What about at 22psi? Would like 2.25 in and 2.5 out be too much? I'm using the car for street/strip. . .
Jeramy
Old Aug 1, 2002 | 01:59 PM
ninesecrx's Avatar
Default Re: 3 inch intercooler piping? (WykidEG)
2.25 inch piping should be good till about 500hp....just use a reducer. Do not use 3 inch. piping as you will loose velocity.
Old Aug 1, 2002 | 09:19 PM
Flamenco-T's Avatar
Default Re: 3 inch intercooler piping? (ninesecrx)
it is FORCED INDUCTION...
velocity and pressure is FAR more important that volume...
I'd take smaller volume at higher pressure any day than bigger volume at lower pressure...
Old Aug 1, 2002 | 10:40 PM
WykidEH's Avatar
Default Re: 3 inch intercooler piping? (Flamenco-NA)
Good point!
Jeramy
Old Aug 1, 2002 | 10:49 PM
accordfreak's Avatar
so would 2" be ok also?
Old Aug 1, 2002 | 10:53 PM
Smashback's Avatar
Default Re: 3 inch intercooler piping? (accordfreak)
Depends on your setup, but most Hondas use 2" at least from the turbo to IC.
Old Aug 2, 2002 | 06:36 PM
Flamenco-T's Avatar
Default Re: 3 inch intercooler piping? (mplex2000)
ideally it's 2.5 to 3" for the intake to compressor inlet, 2" from turbo to IC and 2.25" from IC to TB
Old Aug 2, 2002 | 07:11 PM
abraunb16's Avatar
New User
I run 2 inches off the compressor, then flares to 2.5 inches to the IC and 2.5 inches out of the IC to the intake. I had know a guy locally that ran 2.5 inches in and 3 inches out. He was making decent power with the setup, 277 whp at 7 psi on a basicly stock GSR.
90Rexx
Feb 11, 2010 12:58 PM
Scheizty
Dec 4, 2007 05:46 AM
ThePro
Oct 26, 2004 11:12 AM
2ltrsnailpwr
Jan 29, 2004 06:40 AM
