#3 cylinder dead!
Old Jun 22, 2009 | 07:25 AM
VTEC_PRODUCTION's Avatar
Default #3 cylinder dead!
well i was driving in between el paso and san antonio and if any of you know its a whole lot of nothing. before making the drive i changed my oil and the retards that changed my oil didnt do a good job on tightening my oil filter. somehwere in between the gasket on the oil filter split and i lost alot of oil. i tightened by hand as hard as i could and limped it to the next exit where i filled it with oil and it seemed fine. when i got to el paso it was knocking really bad and so i pulled the engine. after i ripped it apart i was able to see that i didnt TOO much damage but enough to **** me off. the bearing on the number 3 rod was shot to **** and the rod towards the bottom in blacker than all the rest. my question is that i want to rebuild it to be as good as stock again and i want to know exactly what to do to make it reliable again. what exactly do i need to do? do i need to replace the rod? the piston and cylinder look fine from what i can tell but the journal on the crank doesnt look too good. any advice would be great. again it was babied from the time the car started smoking until i ripped the motor out. all the other bearings on the rods and crank look fine. thanks for the help.
**posted in the AM forum for 2 days with no help.
Old Jun 23, 2009 | 03:48 PM
Default Re: #3 cylinder dead!
all these people but no input huh?
Old Jun 23, 2009 | 04:25 PM
philafelman's Avatar
if the crank is scratched, it will probably have to be replaced along with the rod (if scratched)....not sure about the piston, if that cylinder got hot, the wrist pin could have messed it up.
Old Jun 23, 2009 | 05:57 PM
OneBadTurboCRV's Avatar
DO IT ON ALL FOURS
OK... I am lost; this post belongs in the Forced Induction why?
Well, to do it right if the rod has discoloration then you need to replace it. Sometimes shops will break pistons when taking them off because of the press fit pin. They always tell me at least that it is a risk when pressing out the stock pin. Also it does not matter how much you babied it after your motor started smoking/knocking. A spun bearing is still a spun bearing and the crankshaft most likely will need to be turned down. Well then you have to turn down the whole crank and get oversized bearings. Most of the time this is not even worth it by the time you turn the crank you will be half way to a forged one or buying another stock journal diameter crank.
So in the long run I would just replace the crank, at least the one rod, and all of the bearings. For the most part none of the rods should be discolored soooo......???
Obviously you could do it a million different ways while you have the motor apart.
BTW, WTF were you doing having somebody else change your oil?
Old Jun 24, 2009 | 07:49 PM
cuz im going turbo. and the one time i let someone else change it because i didnt have a shop to do it in this happened. im in the military...
Old Jun 24, 2009 | 07:55 PM
stockb18c's Avatar
you live you learn on this one
Old Jun 25, 2009 | 07:08 AM
new crank/better pistons/rods...then ur good to go...since ur going turbo anyways....might as well do ls crank/rods...apparantly gsr cranks are harder to come by.
Old Jun 25, 2009 | 07:29 AM
TurboK's Avatar
Thats some crazy stuff,next time change your oil yourself.hope it all works out for you. you'll need all the parts listed above good luck.
LS97Civic
Apr 24, 2012 07:48 AM
magic hat #9
Dec 12, 2004 07:14 PM
speedymon
Jul 13, 2002 01:35 AM
Rain_man
Jun 20, 2002 03:42 PM
