3 Bar Xenocron Map Sensor.. Now Doesent Run
Old Jul 17, 2007 | 07:10 PM
eleet's Avatar
Default 3 Bar Xenocron Map Sensor.. Now Doesent Run
Ever since I installed the new map sensor, the car has been not running Huh On a 98 ex Y8 with a xenocron 3 bar. I thought it was the chip so I got rid of the basemap and trying different maps in crome but nothing works. Now im starting to think I hooked it up wrong somehow. I totally wrecked the stock one, and I dont wanna revert back and have this be a complete waste of time. Anyone have any suggestions? I took a few pics and a quick video of the problem..
Old Jul 17, 2007 | 07:28 PM
93supercoupe's Avatar
Default Re: 3 Bar Xenocron Map Sensor.. Now Doesent Run (eleet)
u have to change the map so it can run the 3bar, no stock map is going to run with a 3bar map sensor.
Old Jul 17, 2007 | 08:15 PM
mtber's Avatar
Default Re: 3 Bar Xenocron Map Sensor.. Now Doesent Run (93supercoupe)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 93supercoupe &raquo;</TD></TR><TR><TD CLASS="quote">u have to change the map so it can run the 3bar, no stock map is going to run with a 3bar map sensor.</TD></TR></TABLE>
+2
Also, you need leave the stock map sensor installed to block the throttle body port & use a vacuum line to source your vacuum to your map sensor...
Old Jul 17, 2007 | 09:11 PM
eleet's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mtber &raquo;</TD></TR><TR><TD CLASS="quote">
+2
Also, you need leave the stock map sensor installed to block the throttle body port & use a vacuum line to source your vacuum to your map sensor...</TD></TR></TABLE>
Its connected to the tb port with a very short vacume line to the map sensor.
Yes I changed the map in crome.
Old Jul 17, 2007 | 09:49 PM
TunerToys's Avatar
Give them a call. They should be able to help you out. Xenocron is a stand up guy, who will help out if you give him the chance.
Here is the contact info for his shop. Talk to Ian when you call, and he'll do his best to get you running.
Xenocron Tuning Solutions
http://www.xenocron.com
973.846.7872
M-F 9am - 6pm
Craig
Old Jul 17, 2007 | 10:44 PM
eleet's Avatar
Thanks Craig. I currently have a vitara setup on a y8. Using your H-beam rods as well!!
Old Jul 18, 2007 | 01:31 AM
cbustuner's Avatar
Default Re: (eleet)
I always use those for these aftermarket sensors.No worries about proper seal,and I get the same signal/source the oem sensor gets.
Old Jul 18, 2007 | 06:45 AM
TunerToys's Avatar
Default Re: (eleet)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by eleet &raquo;</TD></TR><TR><TD CLASS="quote">Thanks Craig. I currently have a vitara setup on a y8. Using your H-beam rods as well!!</TD></TR></TABLE>
Sweet! Thanks for the sales! If you'll PM us your address, we'll send you a free MAPTER to clean up your MAP installation a little. They are similar to the item cbustuner posted above.
You can check them out here in our store - MAPTER from Tuner Toys
And there is photo installation blog here - MAPTER Installation Photo Blog
Thanks for the purchase, and good luck with your project!
Craig
Old Jul 18, 2007 | 07:55 AM
VTcivicHB's Avatar
Damn you craig, tunertoys just poked another hole in my wallet! That looks clean as hell!
Old Jul 18, 2007 | 08:03 AM
MeanGreenMachine's Avatar
Default Re: (VTcivicHB)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by VTcivicHB &raquo;</TD></TR><TR><TD CLASS="quote">Damn you craig, tunertoys just poked another hole in my wallet! That looks clean as hell!</TD></TR></TABLE>
yeah man tunertoys has some good ****, ill be more than likely purchasing that map sensor adapter from TT as soon as i get boosted.
Old Jul 18, 2007 | 08:49 AM
mike93eh2's Avatar
out of everyone who makes map sesnor adaptors. i think LHT has the cleanest, smallest looking one.
http://www.lhtperformance.net/....html
Old Jul 18, 2007 | 09:46 AM
eleet's Avatar
Thanks Craig. I have purchased from you guys plenty of times in the past. Arp hardware, oil lines, rods, the works. TT is always a interesting site to look at.
Old Jul 18, 2007 | 01:08 PM
TunerToys's Avatar
Default Re: (mike93eh2)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mike93eh2 &raquo;</TD></TR><TR><TD CLASS="quote">out of everyone who makes map sesnor adaptors. i think LHT has the cleanest, smallest looking one.
http://www.lhtperformance.net/....html</TD></TR></TABLE>
Yep, the LHT is pretty clean. If you are connecting with tubing, it's cleaner than ours. If you plan on using the Kavlico, AEM, or different sized tubing, our 1/8NPT threaded port will make it easy to adapt. Both the Kavlico and the AEM will thread right into our fitting.
Craig
Old Jul 18, 2007 | 01:41 PM
cbustuner's Avatar
Default Re: (TunerToys)
The thing I like about the tt piece is the angle of the 1/8th hole.
When I first did mine I used a nipple and it came straight up and since it was so close to the strut bar there was a small kink,so I had to dig up a right angle fitting.Also if I wanted to switch to an aem style map sensor I would have to use a brass street elblow.The tt peice eliminates the need to do either, but when I needed one,they didn't make them yet.
Old Jul 19, 2007 | 02:56 AM
methos713's Avatar
Default Re: (cbustuner)
some nice info here.
Old Jul 20, 2007 | 06:38 AM
Boostedvti's Avatar
I have delt with Tuner Toys and Xenocron,both have excellent customer service!
TT supplied me with my engine parts as well as a custom turbo,all shipped to the UK with NO problems
Give xenocron a call with your problem and I'm sure he'll help you out
Craig,I'll be contacting you and Stacey soon for some more parts for my UK VTi Civic, you konw who I am
Mick
Old Jul 20, 2007 | 09:24 PM
HiProfile's Avatar
Default Re: (Boostedvti)
Make sure the maps were rescaled properly. Since the car starts in 0 Hg" (like WOT), a map that had the scalars changed but not the cell values would make it (in this case) use 40% less fuel at that load point. Add in battery injector offsets that aren't perfect, and its getting less than half the fuel it should be.
BTW wiring looks good, at least that the wires are connected to the right 'legs'. But I always solder my connections, even if its temp.
Old Jul 20, 2007 | 11:02 PM
eleet's Avatar
still have the problem. oh well. xenocron didnt help much.
Old Jul 21, 2007 | 02:06 AM
Default Re: (eleet)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by eleet &raquo;</TD></TR><TR><TD CLASS="quote">still have the problem. oh well. xenocron didnt help much.</TD></TR></TABLE>
thats unusual. he is very helpful, but yet very busy........
Old Jul 22, 2007 | 08:14 AM
mgro's Avatar
Default Re: (eleet)
Check the sensor voltage at the ECU input. If its a 3bar map sensor, it should read about 1.6Volts when the engine isn't running. That way you check both the sensor and the wiring.
Old Jul 22, 2007 | 12:10 PM
HiProfile's Avatar
Default Re: (eleet)
I'm curious how you ruined the stock sensor. It would be unfortunate chasing down the wrong bug if somehow it wasn't the 3bar sensor. As long as voltages are as they should be (idle and while engine off), its not the sensor.
Mind posting any of those 3bar bins, or maybe give us the numbers you used when configuring crome? It *will* be different from the GM 3bar, as well as the other 3bars that may already be input into crome.
Old Jul 23, 2007 | 09:09 PM
JaredKaragen's Avatar
Yeah, the scalars were posted on pgmfi.org recently if I remember correctly.
Old Jul 29, 2007 | 01:01 AM
xenocron's Avatar
Default Re: (eleet)
Wow, yeah..sorry, I've been on my honeymoon for a couple of weeks. Thanks for the vote of customer service when I posted in one of your other threads (on my honeymoon none the less) EXACTLY what you needed to do.
See thread:
http://www.homemadeturbo.com/f...737.0
I have offered for you to SEND THE MAP SENSOR BACK so I can test it for you myself (free of charge)...but I guess I still "didnt help much" at all...again, while I am away trying to enjoy my honeymoon.
Last but not least, I stress again, this map sensor was tested in a car and run before it was mailed off...I know because I did this personally
Old Jul 29, 2007 | 01:33 AM
Kyle R's Avatar
Default Re: (xenocron)
ekk41
Oct 24, 2007 05:28 PM
KRWTEK1
May 28, 2007 12:32 AM
sleeprhatch
Sep 23, 2006 12:04 PM
CiViC SiR
Jul 7, 2003 02:55 PM
phiberoptik
May 6, 2003 09:43 PM
