3 bar MAP sensor and S-AFC
Old Jan 23, 2004 | 11:54 AM
Tushner's Avatar
Default 3 bar MAP sensor and S-AFC
The car is a OBD0, vacuum-advanced timing d16a1/zc ('86-7 Integra engine) with built internals, etc.
Could you guys please link me to any people, threads, sites, etc. where there is info on running more than ~14psi using the S-AFC/450cc combo?
Tuning is no problem - I have plenty of dyno time.
I've searched the site for info and found only people saying it doesn't work because of the ignition advance on OBDI/OBDII, etc. cars. This is not a concern for my setup.
Thanks a ton for any help,
Ryan
redteg87
P.S. I'm not a damned n00b. My account got destroyed somehow.
Old Jan 23, 2004 | 01:11 PM
jazz215's Avatar
i would like to know as well
Old Jan 24, 2004 | 05:03 PM
Tushner's Avatar
Default Re: (jazz215)
TTT
Any link or names?
Old Jan 26, 2004 | 01:26 PM
Tushner's Avatar
Default Re: (redteg_87)
No dice...
Old Jan 30, 2004 | 10:32 PM
Turbo-Honda's Avatar
you cant.. I mean it maybe imposible because I dont think the safc hack can pull that much voltage over 10psi of boost .. If you are really shooting for that much boost, standalone is highly recommended. With all that stuff you put in the motor better off spending little more be safe than sorry. Plus you can change the timing by using the AEM and more...
I'm currently running the same exact thing. b18b safc/440cc and the darn thing cant work well more than 10psi. Just sold the safc, get more for new bottom end and AEM ems is on it way for 20psi..
GOod luck on boosting
Old Jan 30, 2004 | 10:43 PM
rextec's Avatar
the way you run more than 10 psi is to up the fuel pressure with an adjustable fpr used in conjunction with the afc. this way the engine is getting enough fuel and you can stay under 35% with the afc and not throw a code.
Old Feb 5, 2004 | 06:06 PM
Tushner's Avatar
Default Re: (Turbo-Honda)
Thanks for the feedback, Turbo-Honda. Timing is not an issue on this engine, though, as timing is vacuum-advanced - not ECU.
Old Feb 5, 2004 | 06:08 PM
Tushner's Avatar
Default Re: (rextec)
I don't understand the notion of using a FMU in conjunction with the S-AFC. I ditched the FMU to use the S-AFC.
It wouldn't matter whether I had the FMU or not once I pass the stock MAP sensor's range - I'd get a CEL.
Thanks for the reply.
Anyone know anything about running a 3 bar with the S-AFC?
riddlinkid1986
Jul 18, 2008 12:23 PM
ganjasnack
Apr 18, 2008 06:08 AM
rdssk8rcs1
Oct 10, 2006 06:43 AM
nudvl
Apr 4, 2005 04:01 PM
MooreBoost
Sep 19, 2004 05:19 PM
