3 bar map sensor question
Old Sep 13, 2003 | 11:27 PM
Mr. Softee's Avatar
Default 3 bar map sensor question
what exactly does a 3 bar map sensor do? ive heard it just cuts map voltage by 1.7/3 linearly. is this true?
Old Sep 14, 2003 | 12:05 AM
GraphiteAccord's Avatar
Default Re: 3 bar map sensor question (94goldjungsr)
it can read 3 bars of map pessure. One negative, and two positive
Old Sep 14, 2003 | 12:08 AM
Mr. Softee's Avatar
Default Re: 3 bar map sensor question (GraphiteAccord)
i screwd up myquestion. it can read up to 3 bar of pressure, 1 of which is atmospheric, but when it does read this pressure, does the ecu merely see 1.7/3 bar of pressure * actual pressure? in terms of corresponding fuel values with actual map sensor voltage. ahh its so hard to explain lol
like if its 2.7 bar boosted. does the ecu just use the fuel value in 2.7 * 1.7 / 3 = mbar for the mbar value?
sam
Old Sep 14, 2003 | 02:08 AM
MiraiZ's Avatar
depends on what ecu...some use the last highest value...some just dump a whole **** load of fuel
Freemananana
Engine Management and Tuning
12
Oct 16, 2013 02:41 AM
FWD_BEAST
Oct 9, 2012 04:24 PM
ej1252
Nov 3, 2007 07:40 PM
sleeprhatch
Sep 23, 2006 12:04 PM
Javier
Mar 10, 2003 03:58 PM
