2k-4k noise
Old Jun 10, 2005 | 07:45 AM
budget's Avatar
Default 2k-4k noise
every since the summer it started to do this...
everytime i shift inbetween 2k-4k it would backfire but it would sound like a high pitched backfire?? it would only sometimes do this when shifting at higher rpm's.
stock gsr, inline pro, sc61, open downpipe.
i was reading in another thread that in the summer time your car will run a lil richer?
Old Jun 10, 2005 | 07:51 AM
adseguy's Avatar
Default Re: 2k-4k noise (Straight Flush)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Straight Flush &raquo;</TD></TR><TR><TD CLASS="quote">
i was reading in another thread that in the summer time your car will run a lil richer?</TD></TR></TABLE>
I'm guessing you are reffering to what I posted since you PMed me
Yeah a good sign of richness is backfiring. It's very normal on our cars though, but the only real way to check is get/borrow a wideband or check your plugs immediatley after a WOT pull or whereever you want to check for a lean/rich condition. Don't check them if you idled after you did the run because just idleing will ruin the reading
Old Jun 10, 2005 | 07:58 AM
budget's Avatar
Default Re: 2k-4k noise (adseguy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by adseguy &raquo;</TD></TR><TR><TD CLASS="quote">
Yeah a good sign of richness is backfiring. It's very normal on our cars though, but the only real way to check is get/borrow a wideband or check your plugs immediatley after a WOT pull or whereever you want to check for a lean/rich condition. Don't check them if you idled after you did the run because just idleing will ruin the reading</TD></TR></TABLE>
so shut it down immeaditly after a WOT pull? but do you have any idea what i mean by the high pitched backfire sound?
since money is an issue (to get retuned) should i just leave it this way until the end of summer? is it safe? i mean its always hot in TX but only crazy hot in the summer. the tune was running really well up until it got really hot lately
Old Jun 10, 2005 | 08:19 AM
adseguy's Avatar
No I don't know what you mean by high pitched back-fire, but the really hot weather could lead to ungodly high intake temps and lead to detonation. . Check you plugs for signs like little black specs meaning the electrode is chipping off due to the detonation. I wouldn't drive to much like this until you get it fixed. If you do have detonation at lighter loads it shouldn't do to much harm to your engine, but stilll isn't good depending on how hard the pressure spikes in the detonation. Talk to your tuner
Old Jun 10, 2005 | 08:44 AM
budget's Avatar
red cup
Honda Civic (2001 - 2005)
16
Mar 28, 2008 04:55 AM
Draggin99Si
Jan 11, 2006 03:35 AM
Nizzy
Welding / Fabrication
Aug 16, 2004 11:55 PM
blancoteg
Aug 26, 2003 06:50 PM
bwan24
May 25, 2003 01:07 PM
