NITROUS HELP NEEDED
Old May 31, 2008 | 06:50 AM
genia's Avatar
Default NITROUS HELP NEEDED
Okay i got a 99 civic EX d16y8
i was wondering what some of you guys are putting on there with stock internals just intake and exhaust.
What shot should i use?
Do i need tuning?
Is it gonna [freak] with my MAP sensor?
What gear and rpm you spray at?
Thanks
Old May 31, 2008 | 06:59 AM
2literCR-X's Avatar
I had a JDM ZC in a 95 civic coupe, w/ ZEX wet kit, spraying 75 shot w/ stock air box, 4-2-1 Greddy Header and Greddy EVO catback..Depending on what size shot you run, i would recommend if you havent already putting a decent clutch in the car. No tuning needed
Old May 31, 2008 | 07:25 AM
DrivenMC's Avatar
Banned
Default Re: (2literCR-X)
I Put a 75 shot direct port/ wet. Put it on the dyno and got the A/R correct. Still running for 2 years strong.
If your going larger that 75 you might need to take some timing out.
b16bswap
15
Dec 4, 2008 05:39 PM
B!^A@
May 29, 2007 07:31 AM
South sol
Jun 7, 2003 10:56 PM
EFsleeper
Jan 4, 2003 12:24 AM
NewbieGuy
Oct 11, 2001 08:24 AM
