Spark cut instead of vtec? Wtf. Help please
Old 02-16-2012, 06:15 PM
dmullinax96's Avatar
Default Spark cut instead of vtec? Wtf. Help please
I got a eg with a 94 gsr swap, p28 ecu chipped. Been running perfect for the longest, heres the problem..
Vtec is set at 4,500 2 step is set at 5,500 (i know VERY high).
Anyways driving it, when vtec should hit it does a spark cut instead. No CEL's at all, yes my CEL works as well. 2 step doesn't work either, as basically the car won't allow you to rev that high when WARM. But when cold, everything works as should, except vtec obviously because it won't work until warm. 2 step works fine, and it goes through all the rpm's smooth when COLD. Until it starts to heat up, my guess would be the ecu going bad, or a coil or something along those lines. Anyone with some info chime in please?
Can include anymore info you need
Old 02-16-2012, 06:33 PM
The Grumpiest
grumblemarc's Avatar
Default Re: Spark cut instead of vtec? Wtf. Help please
And why do we need a 2-step? And why is VTEC set at 4500? Are you leaving out car details?
Old 02-16-2012, 06:41 PM
No.. bone stock gsr. Hasport mounts, aem fuel rail/fpr, skunk2 intake.
Was set like that when I got it.. but how is "Why is vtec set there and why is the 2 step set there?" related to the question..
Old 02-16-2012, 06:44 PM
The Grumpiest
It relates because people that USUALLY run these things have more modified engines. If you're not throwing a CEL then the first thing I'm going to go with is your "chipped" P28 since the 2 step isn't working either..
Old 02-16-2012, 06:57 PM
Master Detailer
98civdx's Avatar
Why would you ever want your vtec set at 4500!?
Have the ECU looked at, my guess is that is the issue.
Old 02-16-2012, 07:06 PM
Only thing modified is type r cams.
Old 02-17-2012, 03:49 AM
The Grumpiest
WTF? Before you said it was bone stock.
I can see where this is headed. Good luck to you.
Old 02-17-2012, 03:52 AM
O.G. triple O.G.
NVturbo's Avatar
Changing the VTEC set point on a fairly stock setup.......great way to achieve NOTHING.
Old 02-17-2012, 07:58 AM
Relic1's Avatar
VTEC that low on ITR cams... you are loosing power.
your actual question, check your coil, ignitor and the program in the chip.
I've seen all of those things go bad and cause what you describe.
Old 02-17-2012, 03:12 PM
Yes, I do realize this. I did not do that. Regardless, seems as if people are bashing more than they are helping. I asked a question, didn't need people to comment on the setup.. the car has ran fine with that setup for over a year now, so that's not the problem. But where i'm leaning and hoping is the coil/ignitor, also hoping to go to a stock gsr ecu now too
Old 02-17-2012, 03:18 PM
O.G. triple O.G.
NVturbo's Avatar
This is a public forum. There's plenty of people here that can help you out but it seems like you're the one that doesn't want help or cannot accept constructive criticism. You can either search on your own (seems like you didn't) or take our advices and see what's going on with your car. We cant do the work for you.
Old 02-17-2012, 03:33 PM
Ok kind sir.
Thanks for that advice.. that really was helpful information.. thanks for contributing!
EGEAZY
01-31-2010 07:02 AM
92hatch!
Engine Management and Tuning
11
12-11-2009 08:11 PM
DarikDisease
08-26-2008 01:29 PM
pacey
13
09-30-2007 10:13 PM
tuckin15s_8315
06-21-2005 03:13 PM
Quick Reply: Spark cut instead of vtec? Wtf. Help please
