2.5bar map sensor
Old May 9, 2005 | 06:26 PM
Si Shane's Avatar
Default 2.5bar map sensor
Where should I buy one, i want to boost 20-22lb max.
fyi p28 with hondata.
Old May 9, 2005 | 06:50 PM
splitime's Avatar
Default Re: 2.5bar map sensor (Si Shane)
http://www.digikey.com
18bucks... i forget the serial# info though. Check http://www.homemadeturbo.com
edit: found my invoice. MPX4250AP-ND
Old May 23, 2005 | 10:36 AM
1boostedcivic's Avatar
Default Re: 2.5bar map sensor (splitime)
curious, does this map sensor work like the gm map sensor. I plan on running 12psi tops with my uberdata. Just wanna know if this is all i need.
Old May 23, 2005 | 11:01 AM
dennis's Avatar
Default Re: 2.5bar map sensor (1boostedcivic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1boostedcivic &raquo;</TD></TR><TR><TD CLASS="quote">curious, does this map sensor work like the gm map sensor. I plan on running 12psi tops with my uberdata. Just wanna know if this is all i need.</TD></TR></TABLE>
Bump your max down to 10-11 and you can keep the stock MAP, but yeah, if you go over the stock map, this should work. I have one, just haven't installed it and retuned.
Old May 23, 2005 | 11:20 AM
redzcstandardhatch's Avatar
something different
Default Re: 2.5bar map sensor (dennis)
i got one with splitime from digikey or whatever...we hooked it up on saturday to test it out, and we'll be re-tuning the car tonight....
pretty excited to be able to turn the boost up, once my bottom end is complete.
Old May 23, 2005 | 03:52 PM
scttydb411's Avatar
you can stretch the stock mapsensor to 12psi no problems.
Old May 23, 2005 | 03:56 PM
Default Re: 2.5bar map sensor (scttydb411)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by scttydb411 &raquo;</TD></TR><TR><TD CLASS="quote">
you can stretch the stock mapsensor to 12psi no problems.</TD></TR></TABLE>
what do u mean by that? run 12 lbs and hope for no codes???
Old May 23, 2005 | 03:57 PM
also i wanna give u props for keeping ur a/c with ur hf manifold!! good job <TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by scttydb411 &raquo;</TD></TR><TR><TD CLASS="quote">
Old May 23, 2005 | 04:39 PM
b00sted4dr's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by splitime &raquo;</TD></TR><TR><TD CLASS="quote">http://www.digikey.com
edit: found my invoice. MPX4250AP-ND</TD></TR></TABLE>
What a deal.
Old May 23, 2005 | 06:25 PM
scttydb411's Avatar
i've pushed up to 14psi...it get tricky though because you have to manipulate your fuel and timing in the 11psi columns.
i've got 5 sample 2.5 bar mapsensors on the way. hope to see them before the end of the week.
Old May 24, 2005 | 01:14 AM
Calvinator's Avatar
Default Re: (scttydb411)
Bump, let us know how the map sensor works out for you guys.
b18_eg
Engine Management and Tuning
Jul 22, 2017 12:31 PM
journeyquest
Jul 23, 2014 02:58 AM
reddysol
Sep 8, 2007 10:57 AM
zman
Jun 15, 2006 07:40 PM
allanonjj
Jun 23, 2005 02:26 PM
