2.25 enough???
Old Jan 7, 2003 | 10:46 PM
hatch101's Avatar
Default 2.25 enough???
is a 2.25 inch exhaust enough for a turbo SOHC? i know that the 3 inch is recommended, but i have a 2.25 inch right now and i really like it? any imput??
Old Jan 8, 2003 | 12:33 AM
blufke's Avatar
Default Re: 2.25 enough??? (hatch101)
thats fine. dont worry about it.
Old Jan 8, 2003 | 12:58 AM
turbohonda's Avatar
Default Re: 2.25 enough??? (blufke)
It all depends on how much boost/hp you are going to run. With a turbo set up the bigger exhaust the better.
Old Jan 8, 2003 | 11:02 AM
hatch101's Avatar
Default Re: 2.25 enough??? (turbohonda)
well its gonna be just a daily driver so its not gonna run THAT much boost. the max ill run is gonna be like 7-9 psi. oh and its going to be the greddy kit.
Old Jan 8, 2003 | 11:51 AM
mos's Avatar
mos
Old Jan 8, 2003 | 12:12 PM
CzanSOHC's Avatar
Default Re: 2.25 enough??? (mos)
2 1/4 is perfect for that situation. I have an GReddy EVO thats fits 92-00 civics for sale if you are interested, along w/ a high flow cat. PM if interested.
Old Jan 8, 2003 | 12:46 PM
kommon_sense's Avatar
Default Re: 2.25 enough??? (CzanSOHC)
This is good to know. I'm only planning 6-8psi on my d16y8 and kept getting the generic "you need a 3in. exhaust" answer. Does anyone have a table with what size exhaust you need to produce X amount of hp?
Old Jan 8, 2003 | 04:48 PM
blufke's Avatar
Default Re: 2.25 enough??? (kommon_sense)
a free-er flowing exhaust will help no matter what, it just depends on how much noise you want. the bigger it gets the louder(in general). you would probably free up some whp but not enough to justify the cost at this time is what i would say.
Old Jan 8, 2003 | 05:05 PM
nolimits's Avatar
Actually that's not necessarily true. With a larger dia/free-er flowing exhaust you generally lose some lower rpm tq/hp and with proper flow gain some top end hp. Too large exhaust will lose the lower power and not gain anything up top.
Old Jan 8, 2003 | 05:06 PM
bretx0r's Avatar
2 1/2" with a good muffler sounds excellent and the turbo spools quick, even with no catalytic converter.
Old Jan 8, 2003 | 05:38 PM
turbohonda's Avatar
Default Re: 2.25 enough??? (nolimits)
That is true in a NA application but not when it comes to turbos, they create their own back pressure.
Since the down pipe on a Greddy turbo kit is so small the 2 1/4" exhaust should be fine.
[Modified by turbohonda, 6:40 PM 1/8/2003]
Old Jan 9, 2003 | 03:56 PM
hatch101's Avatar
thank god. i have an APEXi n1 and im glad i get to keep it. thanks alot for everyones help.
Old Jan 15, 2003 | 02:30 PM
93LSivic's Avatar
2.25 is fine for what you need.
Hell, I run 2.25 and ran 12.7 @110 on my stock LS motor at 11psi. Im interested to see how much power I will make with the new built motor and 20 psi of boost on the same exhaust.
Old Jan 15, 2003 | 02:33 PM
LS-hatch's Avatar
Yes but your turbo will usually spool up quicker with a bigger exhaust. Exactly how much it will help you with that setup, im not sure. Im thinking of going 2.5" or 3" once im done with my turbo.
Bond
Oct 16, 2005 11:25 AM
shadow103rd
Nov 16, 2004 05:32 AM
rMak
Jun 12, 2004 11:25 AM
superduperman
Mar 21, 2003 02:34 PM
