2.0liter not strong???unreliable???
i was talking with my motor builder today and when i told him i wanted my motor bored and sleeved to 84mm(jdm itr) he said it wont be reliable??will break easier??and the bore will put more stress on the motor and that i should keep it to 82mm and let turbo do most of the work not the motor???did not make sense to me..can someone explain..
Re: 2.0liter not strong???unreliable??? (GOLDBERG)
it is just as strong, except a 84 bore is getting to the point of custom pistons, and when you rebuild you have to bore out somemore so you dont have much material left.. i run a 82 mm bore on my motor and i have no problems
you should be fine on decent aftermarket sleeves but i would reccommend going a little smaller like 83mm so you have room to bore if you break something. If you start out w/ an 84mm bore and break something, 84.5 might be getting a little too thin.
it will work. I ran 84.5mm sleeves on my daily driven car. It was a coupe with a gsr motor. The car never had any problems and took quit a beating for about 8months untill it was stolen. Just make sure to check your oil everyday and don't mess with the tunning that gets done to it.
