1996 ITR Converting back to OBD1
I'm converting my JDM 1996 ITR back to OBD1 for boost,
what will i all need? correct me if im wrong.
obd2a -> obd1 ecu jumper harness
obd2 10pin -> obd1 distributor adapter
obd1 b series distributor.
do i need to do anything with the alternator?
also, best place to look for charge piping for a DC2?
thanks.
thanks.
Who is Mr Robot?
If your engine and accessories are OBD2 then the obd2-obd1 conversion harness and a chipped OBD1 ecu or standalone is all you need.
Who is Mr Robot?
The main features of the OBD2 motor are a knock sensor, a crankshaft fluctuation sensor on the snout of the crank on the oil pump and a toothed timing belt pulley on the crank, the o2 sensors are slightly different IIRC and OBD1 should only have one o2 sensor pre catalytic converter and no postcat sensor so your OBD1 ecu will ignore the second o2 sensor.
jdmjin
Nov 26, 2017 08:59 PM
Adam West
May 8, 2006 03:47 AM
