16.5:1 AFR while crusing, is this ok?
Old Jan 14, 2005 | 12:44 PM
mrx's Avatar
mrx
Default 16.5:1 AFR while crusing, is this ok?
Hi,
actualy i run ~14.7-15.0:1 while crusing (till ~600mbar absolute pressure) which is a good value.
but i thought about leaning the mixture out a bit to ~16:1 whie crusing to improve the MPG? i tried it for a short test and the exhause gas temp. is very low so thats not a problem i think... but are there any other things to say that this is too lean?
power is not a concern, only for the MPG... abot 600mbar the mixture is much richer so that i get no problems there at all...
Thanks
Malte.
Old Jan 14, 2005 | 12:47 PM
EKhothatch's Avatar
Default Re: 16.5:1 AFR while crusing, is this ok? (mrx)
I wouldn't really go more then 15.
Old Jan 14, 2005 | 12:48 PM
Flr Power's Avatar
I do not think you will see an improvement running leaner than 15.5:1 on Honda's.
Old Jan 14, 2005 | 12:49 PM
PM-Performance's Avatar
Default Re: 16.5:1 AFR while crusing, is this ok? (coocoo32)
it will be ok , but if you cruise 14.7-15.0 i wouldnt touch it. it will start bucking once you get like 17's and higher
Old Jan 14, 2005 | 03:41 PM
Tchleung's Avatar
I've cruised around at 16-17:1 A/F, even hit 18 before. car does not buck, drives fine and gets good gas mileage. EGT's were low. I brought t back to 15 tho for peace of mind as not many ppl seem to lean it way uot during crusing/light load.
Old Jan 15, 2005 | 01:08 AM
mrx's Avatar
mrx
Default Re: (Tchleung)
i tried a new rom this morning on the highway... but 16.5:1 seems to be to lean for my car... it didn't drive very well... so i switched back... maybe i lean it out a little bit at very low mbar but i don't think that improve the mpg...
but thanks for your informations.
Malte.
Old Jan 15, 2005 | 01:30 AM
Arturbo's Avatar
Better than steak
25 Year Member
Default Re: (mrx)
You will be perfectly fine running that since you are at a low load. I know some people who will add hondata to their stock car and lean it up a bit under low loads just to get better mpg.
art
dullboy01
Nov 15, 2009 06:36 PM
Si Arn
Aug 14, 2008 11:53 AM
Journeytype-r
Jul 20, 2007 02:41 PM
noob2006
Jun 22, 2006 03:56 AM
WTB AUTO EK
Nov 22, 2004 02:57 PM
