15w50.... when?
Old Oct 22, 2003 | 07:48 PM
mskibbz-T's Avatar
Default 15w50.... when?
OK, I keep hearing great things about Mobil 1's new 15w50 oil, so I picked up a box of them at Schucks in lieu of my typical Mobil 1 10w30. Then I read some more and it seems like 15w50 is more for people running higher boost than me, I'm going to go get tuned tomorrow and will be running 10-12 PSI on my stock block b18b. Is a thicker oil like 15w50 worth it for my situation? I burn a lil oil if I drive it hard, but only if I drive hard. Your thoughts and opinions are welcome
Thanks guys
Old Oct 22, 2003 | 08:05 PM
15psi of fun's Avatar
Default Re: 15w50.... when? (mskibbz-T)
that what i run it's says for turbo cars on the back and Mobil 1 on the front so it good for me
Old Oct 22, 2003 | 08:21 PM
mskibbz-T's Avatar
Default Re: 15w50.... when? (EFrollingout)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EFrollingout &raquo;</TD></TR><TR><TD CLASS="quote">that what i run it's says for turbo cars on the back and Mobil 1 on the front so it good for me</TD></TR></TABLE>
That is what I thought, but then I realized the people preaching about it were running like 20+ lbs... Thanks for posting, I'll change it in tomorrow before I head down to Oregon to get tuuuuned
Old Oct 22, 2003 | 09:14 PM
Johnyquest's Avatar
lol the part on the back that said "excellent for turbo or supercharged cars" swung me too. I've run it ever since i put my turbo on. you have nothing to lose, go with it. it's nice and thick and it doesn't seep by and burn like the thin ****! go for it.
Old Oct 22, 2003 | 11:54 PM
liam821's Avatar
25 Year Member
Default Re: 15w50.... when? (Johnyquest)
ive always ran 10w30....
liam
Old Oct 23, 2003 | 01:07 AM
Unsung's Avatar
What would the advantages be?
Old Oct 23, 2003 | 03:46 AM
swlabhot's Avatar
This is what I currently use. I plan to use this in summer and for track days and 0w40 in Winter for that extra cold start protection..
Old Oct 23, 2003 | 04:22 AM
GruvyTune's Avatar
New User
Default Re: 15w50.... when? (swlabhot)
let me just say, i put in a mix of 0w40 3bottles and 15W50 2 bottles (since winter is coming) and it is awesome. the 5w30 pours like water. The engine now is smoother, less noisy valve train and turbo still spools like a champ.
I think if you do your research you will find that mobil 1 15W50 even for our hondas is a great oil. Someone said something about our oilpumps not being able to handle the thicker oil. that is utter nonsense. show me some proof of that.
the oil pressure when cold is just a bit higher (6 bar) but warm it is about 1 bar vs 10psi with 5w30
Old Oct 23, 2003 | 07:31 AM
mskibbz-T's Avatar
Default Re: 15w50.... when? (GruvyTune)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GruvyTune &raquo;</TD></TR><TR><TD CLASS="quote">let me just say, i put in a mix of 0w40 3bottles and 15W50 2 bottles (since winter is coming) and it is awesome. the 5w30 pours like water. The engine now is smoother, less noisy valve train and turbo still spools like a champ.
Awesome, thanks for all the great responses guys. I gotta go change my oil real quick before I head out Thanks!
Old Oct 23, 2003 | 07:38 AM
ahobbs's Avatar
HELLO,GOOD MORNIN'
I made a post the other day about this kinda. I needed this post thanks.
Old Oct 23, 2003 | 09:18 AM
Ricey McRicerton's Avatar
Default Re: 15w50.... when? (HybridcivicLS-T)
What do you guys do about the thicker oil in the wintertime?? I thought the Mobil 10w30 was only supossed to be good down to like 20 degrees F. It gets colder than that on occassion and Im not trying to go out to my car one morning and have it not start.
Old Oct 23, 2003 | 09:19 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GruvyTune &raquo;</TD></TR><TR><TD CLASS="quote">let me just say, i put in a mix of 0w40 3bottles and 15W50 2 bottles (since winter is coming) and it is awesome. the 5w30 pours like water. The engine now is smoother, less noisy valve train and turbo still spools like a champ.</TD></TR></TABLE>
One more question. You can or cannot mix oil together like this?? I know mixing differente brands of synthetic is a big no no, but what about different weights of the same brand synthertic?
Old Oct 23, 2003 | 11:49 AM
GruvyTune's Avatar
New User
Default Re: 15w50.... when? (Ricey McRicerton)
you can mix any synthetic especially same brand.
it is common practice.
cold weather? add 0W40 mobil 1.
go here and learn.... just one site among many on the internet but a good one...
http://www.bobistheoilguy.com/
Old Oct 23, 2003 | 11:59 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GruvyTune &raquo;</TD></TR><TR><TD CLASS="quote">you can mix any synthetic especially same brand.
Cool, thanks a lot guy!!
Old Oct 23, 2003 | 01:21 PM
SiRkid's Avatar
i ran 5w30
but I just bought 10w30. Guess once i have to change again ill try thr 15w50
Old Oct 23, 2003 | 02:38 PM
NuclearB18B's Avatar
Old Oct 23, 2003 | 02:47 PM
saso
Guest
Posts: n/a
Default Re: 15w50.... when? (ha illuminato un)
The 15 w - 50 is a goos oil for higher temperatures. Trying to keep the range closer eg 15-50 as opposed to a 5-30 means that less addatives. For colder countries a lower numer can be used. One thing to consider is bearing clearances, is the motor new, is a race motor, are the clearances tight or loose. Does the car drag or long distances. I use the red cap Mobil 1 in my street car 400whp damn good stuff. Redline oil in my race car both have given me good results. Pensoil supposedly makes a good oil also.
marcj
Oct 24, 2008 03:03 PM
JDMeg95
Dec 8, 2007 12:02 AM
Pnoyej6
Jul 13, 2006 09:51 AM
rocket256
Dec 22, 2004 04:00 PM
1.8Tities
Apr 18, 2003 02:35 PM
