14b TunerToys oil feed fitting problem!!!!!!!!!!
Old Jul 9, 2007 | 05:55 PM
Rickcrx's Avatar
Default 14b TunerToys oil feed fitting problem!!!!!!!!!!
I have a leaking problem with the fitting goin in to the turbo.Im not sure if the fitting has to be against the bevel in the bottom of the turbo but the fitting i have doesnt go that far.I have tryed high temp thred sealant and a cruch washer and still leaks.If anybody has any ideas how to make it stop or another website i can get the fitting just please let me know.The fitting is 7/16-24 Inverted Flare.Thanx.
Rick
Old Jul 9, 2007 | 06:00 PM
TunerToys's Avatar
Default Re: 14b TunerToys oil feed fitting problem!!!!!!!!!! (Rickcrx)
Hey Rick,
We gladly send you another fitting for your Stealthmode Oil Line kit, but unless you can see somehing wrong with the current fitting, it will probably continue to leak. Do you see a visible problem with the old fitting?
Let us know what you prefer, and we'll take care of it.
Craig
Old Jul 9, 2007 | 06:07 PM
Rickcrx's Avatar
Is the fitting suppost to be flush against the turbo?Cus the fitting i have leave like a 1/16 gap between the fitting shouder and the surface of the turbo.I can send u the money for the fitting with no problem i just want to make it stop.Let me know how much including shipping and ill paypal u the money now cus i need the fitting asap.Thanx.
PS: The only problem with the fitting is u cant fit the line good with a hf mani and 14b turbo cus the fitting is staight up and the line is against the manifold.So i end up welding the 45 degree fitting u send me so i can make the line to go out of the way of the manifold.So for future reference for u company i would say to make a fitting to fit the 14b and hf mani since alot of ppl use this set up.Thanx Craig.
Modified by Rickcrx at 10:23 PM 7/9/2007
Old Jul 9, 2007 | 06:31 PM
TunerToys's Avatar
Default Re: (Rickcrx)
Hey Rick,
That I can honestly remember, we've never had a customer report an issue with these fittings in all the years we've been selling the Stealthmode kits. We'll send you the fitting for free, we just ask that you pay shipping if you want it faster than first class rate.
The inverted flare fittings make their seal in the cone shaped area, not in the threads. The fitting should bottom out against a matching cone shaped area in the turbo's oil inlet connection. When you look into the oil inlet port, it should look like the inside of a brake line connection. There should be a cone pointing up at you inside the hole.
We'll send you the fitting, I just want to make sure it's going to fix your problem.
As for the angle of the fitting, have you clocked your turbo so that there is a vertical imaginary line from the oil inlet to oil outlet? You may have to adjust it a little to get the clearance, but I know that it can be done. (We're running a straight fitting on our budget turbo CRX project).
Thanks from Craig
Old Jul 9, 2007 | 07:01 PM
stealthmode62's Avatar
Default Re: (TunerToys)
Craig,
The 7/16 fitting for the T25 kit must have been sent by mistake in his 14B kit. The fitting he needs is the M12x1.25. They're the ones going out with your order tomarrow. If you don't have any in stock, please PM me with Ricks info and I'll send one straight out to him. Your order will be 3-5 days to get to you anyhow.
Old Jul 10, 2007 | 01:01 AM
Semnos's Avatar
Default Re: (stealthmode62)
Tunertoys and Stealthmode
Old Jul 10, 2007 | 05:31 AM
ragethemachine86's Avatar
Default Re: (Semnos)
the epitome of customer service
Old Jul 10, 2007 | 06:18 AM
Joseph Davis's Avatar
Default Re: (ragethemachine86)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ragethemachine86 &raquo;</TD></TR><TR><TD CLASS="quote">the epitome of customer service </TD></TR></TABLE>
They've always done me right.
Old Jul 10, 2007 | 06:23 AM
Default Re: (Joseph Davis)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Joseph Davis &raquo;</TD></TR><TR><TD CLASS="quote">They've always done me right. </TD></TR></TABLE>
Joseph Davis is a wild banshee in the sack.
Old Jul 10, 2007 | 06:26 AM
Steve, Wifemode has been using your HT account again!
Old Jul 10, 2007 | 06:46 AM
JShull's Avatar
I have dealt with both and I do have to say that both companies have some awesome customer service. (/end threadjack)
Old Jul 10, 2007 | 08:37 AM
Rickcrx's Avatar
They do have great customer service.Btw what kind of thred the 14b have on the oil inlet,12mm 1.25 or 7/16-24.I was searching and i found this info in a DSM forum.
Old Jul 10, 2007 | 09:46 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Rickcrx &raquo;</TD></TR><TR><TD CLASS="quote">Btw what kind of thred the 14b have on the oil inlet,12mm 1.25 or 7/16-24.</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by stealthmode62 &raquo;</TD></TR><TR><TD CLASS="quote">Craig,
The 7/16 fitting for the T25 kit must have been sent by mistake in his 14B kit. The fitting he needs is the M12x1.25. </TD></TR></TABLE>
Old Jul 10, 2007 | 09:54 AM
Schister66's Avatar
Man U FTW
StealthMode
http://www.stealthmodeperformance.com/
i'm famous...
Old Jul 10, 2007 | 10:06 AM
Default Re: (Schister66)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Schister66 &raquo;</TD></TR><TR><TD CLASS="quote"> StealthMode
i'm famous...</TD></TR></TABLE>
haha, you've been famous for about 4 months now. If anyone would like to be customer spotlighted on my homepage, please send me your info. Thanks.
Old Jul 10, 2007 | 10:38 AM
Schister66's Avatar
Man U FTW
haha, you've been famous for about 4 months now. If anyone would like to be customer spotlighted on my homepage, please send me your info. Thanks. </TD></TR></TABLE>
and soon it seems, i will be unfamous...
to good customer service...its becoming rare these days
TypeSLO
Mar 5, 2007 01:48 PM
GeeGee
Mar 22, 2005 04:14 PM
sohc_vtec 2NR
May 6, 2004 10:32 AM
Racer X
Dec 1, 2002 02:34 AM
jdmciviceg
Apr 4, 2002 10:43 AM
