14b
Old Aug 20, 2006 | 04:36 PM
wrinkles's Avatar
Default 14b
i have a 14b im gonna put on my civic and i never really looked at it too close and its my first turbo project and i was wondering what to do with the piping on the compressor side? it doesnt have anything to like hook up a pipe to it its just a two bolt flange like the o2 housing.
Old Aug 20, 2006 | 05:16 PM
97grnrs's Avatar
Default Re: 14b (wrinkles)
there is another part that bolts onto it and turns into a pipe end. ebay has alot of them .
Old Aug 21, 2006 | 09:07 PM
wrinkles's Avatar
Default Re: 14b (97grnrs)
cool thanks
Old Aug 21, 2006 | 09:33 PM
eastbay92cx's Avatar
I believe they call that first piece the "J-pipe." You can get just the flange here if you want:
http://www.roadraceengineering...s.htm
The one labeled "TDO5H Compressor Housing Outlet Flange"
Bolts / cap screws you should be able to find at the hardware store.
It might be easier for you to purchase a used j-pipe if you don't have (access to) a welder, however. Also, if you split the turbo in half (undo the v-band), and remove the large snap ring that holds the compressor housing on, you can knock off the small locating pin, allowing you to "clock" the compressor housing to any position you want, which should make the intercooler piping much easier. If you don't have a welder but still want to do things yourself, you could buy a couple feet of silicone hose, a bunch of clamps, some bends, and bead the pipes with some epoxy or something. The hose is available (pretty cheap) from the same site above, along with some advice on beading pipes w/o a welder. Good luck.
Old Aug 22, 2006 | 05:47 PM
wrinkles's Avatar
Default Re: 14b (eastbay92cx)
can i use a stock eclipse one or do i have to make my own?
and a little of track anyone know the psi the wastegate is set to stock on one of those?
Old Aug 22, 2006 | 10:10 PM
You should be able to use the stock eclipse one, or at least part of it. the stock wastegate is about 8-10 psi i don't know exact but whatever it is its fine for a stock engine.
Old Aug 23, 2006 | 11:15 AM
wrinkles's Avatar
cool thanks for the info, cant wait to be boostin finally!
yakuza
Jun 28, 2008 08:02 AM
hondaguyexsi
Aug 7, 2005 06:41 PM
RNPoo7
Jan 7, 2005 09:54 PM
Matt B
Mar 18, 2004 05:46 AM
johnisenglish
Oct 28, 2002 06:40 PM
