12.5:1 Compression and Nitrous??
Old Mar 2, 2005 | 08:00 AM
BigBodySmith's Avatar
Default 12.5:1 Compression and Nitrous??
I am an all motor guy, just doing a little research on high compression motors with nitrous. I did do a search, found out alot of info, about retarding the timing, running rich. Just seeing who is actually running nitrous on a 12+ compression motor.
I am running endyn rollerwaves 12.5:1 compression, eagle rods, STOCK Sleeves, with Skunk2 Stage 2 cams and full valvetrain. If I were to spray, I would use the Hondata s200 with nitrous control. It will not be anything big, just a 75 shot, for 3rd and 4th gear incase I am not doing well .
Please give me your thoughs
Old Mar 2, 2005 | 10:31 AM
No one has ran nitrous on a 12+ compression motor!!!
Old Mar 2, 2005 | 10:39 AM
m R g S r's Avatar
Default Re: (BigBodySmith)
That motor should love the nitrous. . . Assuming it's tuned properly. . .
Old Mar 2, 2005 | 10:44 AM
turboEGhatch's Avatar
Default Re: (m R g S r)
We run nitrous on a 16:1 motor, albeit not a honda
Nitrous goes great with high compression.
Old Mar 2, 2005 | 10:50 AM
Id really like to talk to someone who is currently running a nitrous fed high compression motor. Just have a few questions.
Old Mar 2, 2005 | 11:53 AM
rico91stang's Avatar
I ask Twitter, not xtrac1
Community Builder
Community Influencer
What question do you have?
Old Mar 2, 2005 | 12:26 PM
mrbsponge's Avatar
i ran 12+ compression on a honda motor an nitrous what questions do you have, i can already tell you that you will be fine as long as you are using forged pistons and not cast OEm units
Old Mar 2, 2005 | 06:19 PM
anyone else
Old Mar 12, 2005 | 04:05 AM
animal chin's Avatar
Default Re: 12.5:1 Compression and Nitrous?? (BigBodySmith)
bringing it back from the dead,,,,,,,,,,,,,,,
Old Mar 12, 2005 | 04:27 AM
quicksol95's Avatar
Default Re: 12.5:1 Compression and Nitrous?? (noman)
nitrous is a high compression motor's friend
Old Mar 12, 2005 | 04:44 AM
DaveF's Avatar
Default Re: (turboEGhatch)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by turboEGhatch &raquo;</TD></TR><TR><TD CLASS="quote">We run nitrous on a 16:1 motor, albeit not a honda
Nitrous goes great with high compression.</TD></TR></TABLE>
probably runs on alcohol or nitromethane, ................
i couldnt imagine how high the cyl pressures and temps would be with a 13.5:1 4 cyl engine trying to spray huge "shot" of nitrous.............
Old Mar 12, 2005 | 09:17 AM
MooreBoost's Avatar
Default Re: (Dturbocivic)
Spray more than that.
How about a 150 direct port?
tempsohc
15
Mar 11, 2011 06:08 PM
MooreBoost
Feb 18, 2005 10:17 PM
turbohf
Apr 13, 2003 11:51 AM
lsteggy
Nov 6, 2002 09:40 AM
xxplosif1
Sep 18, 2002 06:24 AM
