10 sec. d16 Ej BUILD!!!
Old Apr 13, 2010 | 07:05 PM
  #26
madblkscientist's Avatar
Default Re: 10 sec. d16 Ej BUILD!!!
GL nice project
Old Apr 14, 2010 | 05:10 PM
  #27
93DXEG's Avatar
Originally Posted by Autoworks
GL w/ the build
Thanks
Old Apr 14, 2010 | 05:11 PM
  #28
93DXEG's Avatar
Originally Posted by madblkscientist
GL nice project
thanks
Old Apr 15, 2010 | 05:54 AM
  #29
Edel's Avatar
Nice Build
Old May 17, 2010 | 06:00 PM
  #30
I CRX I's Avatar
shake and bake!! wheres the updates??
Old May 19, 2010 | 02:01 PM
  #31
93DXEG's Avatar
Sorry expecting a babygirl in the next few weeks. Will post some pics tommorow night preping car for primer! (inside and out)
Old Aug 5, 2010 | 10:39 PM
  #32
Crackdonalds's Avatar
Originally Posted by 93DXEG
Installed L.E.D shift light!
What labor did you do to install your shift light?
Old Aug 6, 2010 | 11:15 AM
  #33
joe111599's Avatar
Congrats...when is she due or is she already here?
Also, how well do you think that 60-1 will perform on the d-series? I was going to go that route but was told I should go with something smaller. I was gonna go with the 60-1 (.48 a/r) but went with a Precision sc34 (.48 a/r) instead. I am still curious to see how the 60-1 will perform. Anyone else ever run a 60-1 on a d-series?
Old Aug 10, 2010 | 03:15 AM
  #34
iwouldHITit's Avatar
what does the comp ratio come out to with the vitara pistons and fj custom rods??
Old Aug 10, 2010 | 07:46 AM
  #35
ReDemoN's Avatar
DixielandImports Please
Im selling my mini ram mani and downpipe.
Pm if interested.
Old Aug 10, 2010 | 07:57 AM
  #36
Ls_dx's Avatar
So far so good man, Lovin the buDget build
Old Aug 10, 2010 | 08:00 AM
  #37
boostedeg302's Avatar
Looking good. In for progress!!
Old Feb 2, 2011 | 06:36 AM
  #38
93DXEG's Avatar
Hey thanks she was born 6-12 and wow i have been broke busy and have a daughter... but now am back to finish this project! In caseyour still wondering about which turbo it depends on your goals i have read about some d-series that do well with tbis turbo.
Old Feb 2, 2011 | 06:47 AM
  #39
93DXEG's Avatar
I'm finally gonna continue, ordered top mount manifold with 44mm vband housing. Ordering everything else with tax return 2 weeks. Oh and i started a reef tank that held me over till now.
Old Feb 2, 2011 | 06:50 AM
  #40
93DXEG's Avatar
8:5:1 im getting head and block milled to bump to 9:5:1 car will be on e85 hopefully no detenation...
Old Feb 2, 2011 | 07:23 AM
  #41
93DXEG's Avatar
Took apart cluster drilled hole with hole saw jb welded led soldered 2 wires to the back of led then connect wires to adjustable voltage regulator from radioshack wired that to check engine light and that was it. ( regulator dims led and led cannot handle 12 volts so it was necessary.)
Old Feb 2, 2011 | 12:57 PM
  #42
sonicivic's Avatar
i run a 60-1 with a .63 backside, does great...had a garrett 57 trim with a .48 before and it surged at full boost(23psi).......i would not recomend a .48 backside to anyone wanting to go tens on a d16
Old Feb 3, 2011 | 01:37 AM
  #43
93DXEG's Avatar
I have. 63 hot side so what kind of numbers did u put down? Dyno graph would make you my new best friend! I relly want precision 6262 car will be 90% track car. Anyone want to buy a brand new turbo? Lol
Old Feb 3, 2011 | 11:35 AM
  #44
blackmugensivic's Avatar
Good luck, looks great
Old Feb 15, 2011 | 05:59 AM
  #45
93DXEG's Avatar
t3 topmount with 44mm v band wg flange
elivandenbosch
Appearance Build Threads
52
Jun 21, 2008 08:29 PM
DeltaCharlie2
Paint and Body
35
Jun 15, 2008 11:16 AM
Jon Vito
Nov 8, 2007 06:17 AM
Vero
Feb 14, 2005 10:01 PM
GODluvsLUDES
May 4, 2003 08:34 PM
