1/2 BSP 90 degree Fitting: Where do I find two of these for my oil cooler??
i'm trying to find two of these, I have been searching the internet with not much luck.
I found a place called mini mania.com but they said it would take them 6 weeks to get these, screw that, I'll just find where they get them from and not have to pay their markup.
Re: 1/2 BSP 90 degree Fitting: Where do I find two of these for my oil cooler?? (mike1114)
you think you can run AN lines??? if you can i have a 10an 90 degree fitting i need to get rid of. not sure if thats what your looking for exactly though
Re: 1/2 BSP 90 degree Fitting: Where do I find two of these for my oil cooler?? (playahwitgame)
Thanks, but the egay oil cooler I have has bsp fittings.
I have fittings that are straight but it makes for a very hard install, I need some 90 degree ones so that I can put the oil cooler in the wheel well area.
even bakerprecision.com didn't have them!!
B.A.T. (British American Transfer) located in Sarasota, FL is the Mocal importer and should have these on the shelf. They have more BSP than anyone.
941-355-0005 ask for Eric or Peter. Please tell them I referred you.
Jim Justice
Jim Justice
Re: 1/2 BSP 90 degree Fitting: Where do I find two of these for my oil cooler?? (doublej)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by doublej »</TD></TR><TR><TD CLASS="quote">B.A.T. (British American Transfer) located in Sarasota, FL is the Mocal importer and should have these on the shelf. They have more BSP than anyone.
Jim Justice</TD></TR></TABLE>
Wow good info!! I found their website and they definatly have many hard to find fittings!! http://www.batinc.net/
Re: 1/2 BSP 90 degree Fitting: Where do I find two of these for my oil cooler?? (97turbols)
That is good info....I'll be callin them tomorrow.
Thanks Jim!!!!
Thanks Jim!!!!
Jim Justice and BAT For the Super Motal Kombat Finish Move Win!!!!
Had them in stock, and cheaper than anywhere. Since Im in Fla like BAT, they will get here tomorrow!!
