Valve lash question
Old Aug 8, 2006 | 02:55 PM
OBRJosh's Avatar
Default Valve lash question
If the valve lash was way off on a b16 turbo how much compression would you lose Alot, Alittle, ? any feedback or anyone have any experince with valve lash set too tight please feel free to post
Old Aug 8, 2006 | 05:13 PM
boostedcivicsir's Avatar
Mr. Badwrench
Default Re: Valve lash question (OverboostJosh)
well if it is tight, depending on how tight, it may hang the valve open. if let go too long, it will burn the valve. if it is loose, it would have to be really loose to affect compression.
Old Aug 8, 2006 | 05:48 PM
OBRJosh's Avatar
Default Re: Valve lash question (boostedcivicsir)
thanks man acully its way to ******* tight, i wont metion any names but they got set at .001 on intake and exhaust instead of .006ish .007ish on exhaust im hoping this is the reason i have 130ish compression and only ran a 14.5 at 100mph with 9psi on a TO4e when last year i ran a 15.6 at 87mph stock b16
Old Aug 8, 2006 | 05:51 PM
Mr. Badwrench
i do 0.007 on both sides. just lazy he hee. but yeah 0.001 is way too tight.
Old Aug 8, 2006 | 05:52 PM
Turbo-LS's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by OverboostJosh &raquo;</TD></TR><TR><TD CLASS="quote">thanks man acully its way to ******* tight, i wont metion any names but they got set at .001 on intake and exhaust instead of .006ish .007ish on exhaust</TD></TR></TABLE>
Yeah we wont mention any names mister i didnt read the complete paragraph in the honda building book
Old Aug 8, 2006 | 07:56 PM
Muckman's Avatar
Moderator in Chief
If the valve is open even a tiny bit you will have a very bad result from a compression test.
Old Aug 9, 2006 | 04:06 PM
TURBO4drTypeR's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by OverboostJosh &raquo;</TD></TR><TR><TD CLASS="quote">thanks man acully its way to ******* tight, i wont metion any names but they got set at .001 on intake and exhaust instead of .006ish .007ish on exhaust im hoping this is the reason i have 130ish compression and only ran a 14.5 at 100mph with 9psi on a TO4e when last year i ran a 15.6 at 87mph stock b16</TD></TR></TABLE>
i always do .006 on intake and .007 on exhuast(tightest you can go) that way if your motor makes any noises then something is not right...
Old Aug 9, 2006 | 04:09 PM
OBRJosh's Avatar
Default Re: Valve lash question (TURBO4drTypeR)
yea just set them to .007 today and is ticking like a **** compression went way up but its ticking BADD wasnt ticking before i adjusted them, so i tihnk i gots some problems
Old Aug 9, 2006 | 04:35 PM
Mr. Badwrench
leak down, if it was tight you may have bent one.....worst case scenerio.
Old Aug 9, 2006 | 04:37 PM
you probably have bent valve/s now... anyhow goodluck to you...
i hope you get it fixed and be back up again
Old Aug 9, 2006 | 05:29 PM
OBRJosh's Avatar
Yea sorry guys i screwed up cly 2n4 had them way loose my first valve lash job hehe but i just checked all of them and i realised what i did and Now shes purring like a kittin thanks everybody
Old Aug 9, 2006 | 05:56 PM
Turbo-LS's Avatar
BONE HEAD !!!!!!
Old Aug 25, 2006 | 09:18 AM
jz98ctr's Avatar
GOD..you 'Staven kids need to pay attention lol
Old Aug 25, 2006 | 09:22 AM
93supercoupe's Avatar
Default Re: (jz98ctr)
god damn CT homo's
SlowB20z
Sep 17, 2012 09:49 AM
proj21
Oct 1, 2009 02:40 PM
moesrex
May 23, 2006 08:55 AM
BlAcK_eL
Jul 31, 2005 10:25 PM
JFG Kevin
May 12, 2004 03:44 PM
