**what do you think of this problem?
well i blew up my motor last week and this is my deal now "Temporarily", check it out
original setup
d16z6
14b turbo running 10lbs
greddy front mount
255 fuel pump
arp head studs
Srp 9:1 pistons
cometic headgasket
current setup
d16z6 head
new plugs
d16Y8 stock bottom end
stock headgasket
running 10lbs again
<U>current problems</U>
-CEL code 41 o2 sensor
-noticeable loss of power
-some smoking from the exhaust
-slightly bouncy idle from 900 to 1200k
do you think that the o2 sensor could make it feel so slow now?
original setup
d16z6
greddy front mount
255 fuel pump
arp head studs
Srp 9:1 pistons
cometic headgasket
current setup
d16z6 head
new plugs
stock headgasket
running 10lbs again
o2 sensor really wont make a difference. What color is the smoke? Black? Blue?
Id do a leak down test, and a compression test. Make sure the motor is all happy. Have you checked the timing? If the timing is off it will make it feel really weird.
liam
liam
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by oxSLEEPERxo »</TD></TR><TR><TD CLASS="quote">what fuel management are you running?</TD></TR></TABLE>
s,oke could be caused from worn seals in the turbo...or residual oil in the line or intercooler..or exhaust....breaking up could be caused by bad o2 sensor or faulty wire on 02 sensor...also timing might be retarded too much causing loss of power..
Dasfinc
Jan 29, 2008 06:31 AM
DelSolDon
Jun 22, 2007 08:34 AM
DelSolDon
Jun 19, 2007 02:26 PM
racinskittle
Oct 26, 2003 08:36 PM
soHybridized
Apr 27, 2003 06:22 PM
